Radiator Cooling with Grillcraft MX Grilles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vege-Taco, Aug 19, 2008.
  1. Aug 19, 2008 at 3:16 PM
    Vege-Taco
    Vege-Taco [OP] Chips and Salsa Specialist
    Shawn
    Arizona
    2017 Tesla Model S 100D
    Bugs on the windshield
    Has anyone done any comparisons in how well the truck cools with the Grillcraft MX Grilles vs. the stock grilles? I'm a bit concerned that the mesh will act more or less like a solid blocked off grille at normal highway speeds.
    Have any of you that run these grilles noticed the fan running more often than before the install? Did anyone bother to check before and after coolant temps with a ScanGauge or other monitoring device?
    With 110+ degree summer temperatures and an additional radiator in the stack for my supercharger I can't really afford to lose cooling ability.
  2. Aug 19, 2008 at 4:29 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Have you looked at 1) putting a fan switch in and 2) replacing your coolant with water wetter to improve your temps now??
    Do you tend to run hot now??
  3. Aug 19, 2008 at 4:30 PM
    zombot
    zombot Scavenger
    savannah
    08 white debadged panda
    bull bar and offroad lights, tool box and other minor storage mods
    not only do i have the grillcraft, but i also painted my radiator black, and live in the hot south.
    i haven't seen a needle difference or heard the fan act any different.
    haven't run any diagnostics or have a supercharger though, so....
  4. Aug 19, 2008 at 4:37 PM
    Vege-Taco
    Shawn
    Arizona
    I'm currently running stock coolant. I do plan on running water wetter when I do a flush next spring though. Currently my WT runs about 193-195 degrees at 65 mph and 106-110 degrees outside.
    I'm just afraid that if I cut my grille up and install the Grillcraft I may see 205 degrees or some such. I really don't want to go there.
  5. Aug 19, 2008 at 4:44 PM
    BLOCKADE
    BLOCKADE Well-Known Member
    TRD Off Road
    Weather Tech Floor Liners, Front Bed D-Rings...
    I don't think the stock fan would run any differently, even if the truck was running hot. It's not thermostat driven, it's on a belt with the rest of the accessories, isn't it?
  6. Aug 19, 2008 at 4:45 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...I don't blame you. The extra super cooler would make me weary too- but I think you'll be ok.
  7. Aug 19, 2008 at 5:04 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Yeah I live in SOCAL where it is about 120+ this time of year and I too have the Grillecraft and have painted behind it black. I do not have the supercharger however I have seen no difference in the temp since the upgrade, I can tell you that the new grille keeps the rocks and flying debris out of your radeator.
  8. Aug 19, 2008 at 10:32 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Ditto here in Socal. No problems. No supercharger though. The mesh isn't so small that it would restrict air.
  9. Aug 20, 2008 at 4:44 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Coolant temp before grillcraft grill on a 70 mile run over mixed highway and limited access backroads was between 184 and 188 on tthe scanguage.
    Coolant temp after grillcraft grill on the same 70 mile trip the following weekend was between 184 and 188 on the scanguage.
    I too was curious about the effects so I did check it.
    For those of you considering this mod and planning to rattle can your radiator.
    ONLY USE EASTWOOD RADIATOR PAINT. Anything else does not have the correct heat dissipating properties and could potentially adveresly effect your cooling. One can of the eastwood radiator paint is about $12, So yes it does cost more than a can of krylon, but it is worth it in my oppinion.
  10. Aug 20, 2008 at 5:20 AM
    Vege-Taco
    Shawn
    Arizona
    Thanks for the info. Is Eastwood Radiator paint an easy item to find?
    Also, regarding the radiator fan on our trucks. Does it have a clutch that engages and disengages or is it always sucking air?
  11. Aug 20, 2008 at 9:32 AM
    Evil Monkey
    Robert
    Escondido, CA
    You also don't have to put a lot on. I used just enough to dull the shine off the aluminum.
  12. Aug 21, 2008 at 4:12 AM
    maverick491
    South Jersey
    Eastwood radiator paint click here.
    The fan in our trucks is a clutch fan (technically) but the fan is always sucking air, it is just that when the clutch is disengaged it is sucking less air as the fan spins at a reduced rate of speed, and then when the thermostat reaches the perscribed temperature the clutch engages and brings the fan back up to full speed again.
    Regards
