Radiator Fan proper function?; PO 128; 2002 Toyota Tacoma Prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by sewardsfolley, Nov 17, 2024.
  1. Nov 17, 2024 at 4:51 PM
    sewardsfolley
    sewardsfolley [OP] Member
    2002 Tyoyota Tacoma Prerunner 4 cylinder 2.7 L
    My simple question: Should the radiator fan not be rotating when the engine is cool? What is the proper behavior of the radiator fan for my 2002 truck? Does the radiator fan on my truck run all the time and then shift into faster rate when the engine needs cooling or should it stop about 30 seconds after starting and start up only when the engine begins to get too hot?
    The reason I ask:
    I have gotten a PO 128 code for My 2002 Toyota Tacoma Prerunner 2.7 liter 4 cylinder truck. The code suggests that the engine coolant temperature is below the thermostat's regulating temperature. The thermostat display in the cab for the engine never gets to the normal running temperature and it shows that the engine remains running cool even on a long drive.
    One possible malfunction to rule out is that the fan clutch is not working and cools the engine when it does not need cooling.
    I have changed a temperature sensor and the problem continues. There is plenty of coolant in the cooling system; that's not the problem. I may replace the engine coolant thermostat (which may be stuck open cooling the engine); this is often the problem for a PO 128. But before doing that I want to rule out the fan. It is running even a few minutes after the truck has started. It appears possible that this may be why the engine is not properly heating up. If so then I think that I will need to replace the radiator fan clutch. Help!
  2. Nov 17, 2024 at 7:00 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    The viscous fan? Yeah, they will spin even when not fully engaged, but it's just drag.
  3. Nov 17, 2024 at 7:01 PM
    MadNachos
    If in doubt just remove the viscous fan and take a short test drive. But don't sit in traffic.
  4. Nov 17, 2024 at 7:08 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    More likely than anything, you have a thermostat stuck open. If the thermostat is closed and allowing things to heat up, the fan clutch can’t possibly overcool the engine to prevent the thermostat from opening. In other words, a fan clutch can’t cause an overcooling problem because the thermostat sets the minimum operating temp.
    and yes the fan is always going to spin. When it’s cold like right at startup, it will somewhat roar until the fluid in the clutch disperses and spreads out and thins out. Then the fan will freewheel as much as it can until warm up, but it will still always spin, just with very little load. Then when the air from the radiator gets warm, the fan clutch will start to engage and it will slip a lot less, moving a good bit of air for cooling.
    JustADriver, FixMyTaco and ControlCar like this.
  5. Nov 17, 2024 at 7:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    When the engine is cold. Reach down a spin the cooling fan. It should spin fairly easy.
    There will some resistance, but not a lot.
    Then try it on a war engine. It should be hard to spin.
    If yours is always hard to spin, it may be the fan.
    But that type of failure is not common.
    ControlCar likes this.
  6. Nov 17, 2024 at 7:46 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    T stat my 1st choice
    MadNachos likes this.
  7. Nov 17, 2024 at 7:46 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes the fan spins all the time, the fan clutch regulates how fast it spins.
    In any case it wouldn't matter if the fan clutch was fully engaged or not as far as the engine running too cool, the thermostat regulates the flow of coolant through the radiator and thus engine temperature. The fan is there to force air through the radiator when the vehicle is stationary or moving at low speed to keep it cool, it can't cause overcooling.
    I will caution that on some Toyota models the P0128 isn't a thermostat code but instead an O2 sensor code however in this case code set criteria states it sets when coolant temp fails to go above 167F after the engine has been running for a length of time. 95% of the time it's a failed thermostat that is either stuck open or opening too early.
  8. Nov 17, 2024 at 7:49 PM
    sewardsfolley
    Yay!...With these beautiful insights I will go ahead and replace the thermostat. Thank you!
    I have never drained a cooling system. I guess just use a clean 5 gallon bucket and pour it back in after the fix...correct? The thermostat easy to get to and I have watched some videos on how to do it. I changed the front brake pads and rotors today!
  9. Nov 17, 2024 at 7:53 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd put fresh coolant (Toyota Red) in it if it's never been changed or your unsure of it's history, it only holds about 2 gallons so that's 1 gallon of full strength and 1 gallon of distilled water or 2 gallons of 50/50 pre-diluted.
  10. Nov 17, 2024 at 8:19 PM
    sewardsfolley
    I will take that advice. Thank you.
  11. Nov 18, 2024 at 12:55 PM
    Glamisman
    Glamisman Well-Known Member
    There are 2 coolant temperature sensors on your motor, one is for the PCM and the other is for the temp guage in the combination meter.
