Radiator Fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kahanabob, Dec 30, 2022.
  1. Dec 30, 2022 at 2:51 PM
    kahanabob
    kahanabob [OP] Well-Known Member
    Maui
    16 TRD 2WD 4DR
    I just want to drain radiator and add new fluid. No flushing!. Searched everywhere, how many jugs of fluid will i need to buy to fill it back up?
    AM6217 likes this.
  2. Dec 30, 2022 at 2:54 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
  3. Dec 30, 2022 at 3:09 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I don't understand why, only drain and fill (radiator) your contaminating the new with what's left in rest of system. You would never drain half your oil...
    HondaGM likes this.
  4. Dec 30, 2022 at 3:11 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    This is similar to what people do with the transmission.
    HondaGM and Big tall dave like this.
  5. Dec 30, 2022 at 3:12 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    3-4 quarts
    HondaGM likes this.
  6. Dec 30, 2022 at 3:12 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    HondaGM likes this.
  7. Dec 30, 2022 at 3:17 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    I know, i just don't want to get into doing the whole flush. have a 2016 with 27K miles on it so i am just going to drain the radiator. i am a old fart, at the point where every thing i touch turns into a goat rope.
  8. Dec 30, 2022 at 3:21 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Post of The day right there….
  9. Dec 30, 2022 at 3:21 PM
    na8rboy
    WI
    Exactly, just doesn't make sense.
    HondaGM likes this.
  10. Dec 30, 2022 at 3:31 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Yep, I do the same with my power steering fluid too. Suck the fluid reservoir dry and refill with fresh PS fluid every engine oil change.
    I'm sure there's a least a litre+ of engine oil left in the block, heads and oil galleries during an average oil change anyway. Draining and refilling the rad every once and a while can't hurt either IMO....
    HondaGM, RustyGreen, AM6217 and 2 others like this.
  11. Dec 30, 2022 at 3:44 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Only 27k and you’re changing the rad fluid? Waste of time and money.
  12. Dec 30, 2022 at 3:45 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    What’s a goat rope?
    ancient11, Mas Olas and HondaGM like this.
  13. Dec 30, 2022 at 3:47 PM
    Bishop84
    Bishop84 Well-Known Member
    Coolant gets acidic with age. 2016 was awhile ago now. Superlong life is good for 5-10 years, but early won't hurt it.
    Draining the rad usually needs 1 and 1/2 gallon. So 2 jugs. Nothing wrong with preventative.
  14. Dec 30, 2022 at 3:58 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    I do this every 2 years on all of my vehicles. Same with the power steering fluid and brake fluid.
  15. Dec 30, 2022 at 3:59 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Actually there is some logic here for the coolant and transmission.
    The fluids don't wear out so much as the additive package does, by changing a percentage of the fluid you get some fresh additives (protection) in the system with a minimum of work and expense.
    Old cars with long neglected automatic transmissions may have a fair amount of build up. A full fluid change puts a lot of fresh (full strength) additives in the transmission at once, that might cut loose enough build up to cause issues. A soft change of 2-3 quarts each oil change is a milder way to clean things up.
    Easy to do with a fluid extractor on the older models with a dip stick.
    I have purchased old cars with black power steering fluid, the steering racks get "sticky" feeling. Simply by sucking the reservoir dry and refilling a few times the black fluid and the sticky feeling will be gone, repeating occasionally during oil changes keeps the fluid clear.
    Big tall dave and HondaGM like this.
  16. Dec 30, 2022 at 4:11 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Like a FUBAR.
  17. Dec 30, 2022 at 5:45 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    old persons saying, when you get yourself into a situation that keeps getting worse and worse.
    goat rope (plural goat ropes) (slang) A confusing, disorganized situation often attributed to or marked by human error. quotations
  18. Dec 30, 2022 at 6:05 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Well, how do you change it all when you can't get the fluid undiluted?
  19. Dec 30, 2022 at 6:12 PM
    na8rboy
    WI
    You can drain the whole system. Also system can be flush which pushes old fluids out. Same as brake fluid flush. Verses radiator drain, which maybe 50% of fluid change.
  20. Dec 30, 2022 at 7:44 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
