Radiator flush Coolant ratio question.
Discussion in 'Performance and Tuning' started by Rucas, May 29, 2013.
  1. May 29, 2013 at 12:51 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    So I'm flushing the coolant system but have a question.
    If I:
    1. Drain the radiator
    2. Add Distilled water and run the truck so it circulates.
    3. Drain again
    4. Add distilled and do another flush.
    yada yada yada
    it calls for a 50/50 mix i know. but it also says that the engine block contains about 50% of the fluids. So if I do these flushes with distilled water that means when I go to fill it with the 50/50 mix I need to take into account that there's the distilled water in the block still.
    Meaning that the mix I put into the radiator should be closer to a 75/25 (Coolant/water) so that when it mixes with the rest of the water in the block it will be 50/50.
    Yes? No?
  2. May 29, 2013 at 12:59 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    1. Drained 2. Refilled with 50/50 3. Done
  3. May 29, 2013 at 1:10 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    fuck it.
    okay cool.
  4. May 30, 2013 at 6:49 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you are flushing with distilled, I would add the 50% amount of straight coolant, then top off with as much distilled as needed. Also, draining the block is pretty easy, just need a few extensions.
  5. May 30, 2013 at 7:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    At some point, you need to flush with 50/50 and run it until it cycles to get the distilled out of the block. And of course, continue to let it cycle to burp/bleed the system to get the air bubbles out. By that time, you should have all 50/50 in the system.
  6. Jun 20, 2013 at 11:32 AM
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    I have read many angles on this so far. Some say drain and fill, some say drain, fill, run the engine, top it off and repeat.
    Anyone got a link to a write-up on flushing the coolant? I just need a solid method for this.
  7. Jun 20, 2013 at 11:50 AM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    I did
    drain, fill with distilled
    run for 10 minutes
    fill with coolant.
    went to Moab and all just fine.
  8. Jul 22, 2013 at 4:59 PM
    brandonlamb25
    brandonlamb25 Well-Known Member
    Georgia
    08 Crewcab Prerunner V6
    K&N Intake, Wet Okole Seat Covers, Ipod to Factory radio hookup kit, Black Low Pro Toolbox, Toytec Coilovers and 285/75r16 BFG MT's
    how many times did you flush with distilled?
    did you use a radiator cleaner?
    how did you slove previous issue about water in the block?
    i'm doing this in the am. Thanks
  9. Jul 23, 2013 at 6:53 PM
    darktaco
    darktaco Active Member
    N.E. , Pa...U.S.A.
    08/Sport
    scangauge/c.b.-cobra 29/ BO chrome badges/Demello bolt on sliders/rcbs 4x4 led mod/rear tsb / relocated trailer plug to plate light hole/ Toytec U.L.K./L.R. UCA's/AFE-pro-dry air filter/LEDS -plate,dome,map lites /rear diff breather/ImMrYo's mirror lift/redline hood lift,
