radiator flush problems....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brandonlamb25, Jul 23, 2013.
  1. Jul 25, 2013 at 8:50 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    There are two. Driver's side is in about the same place as passenger, but requires some more acrobatics to see and get a socket on it. I used 3 x 6 inch extensions and a wobble to get to it.
  2. Jul 25, 2013 at 9:03 AM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    Sorry for late post but yes there are 3 coolant drain for the 2nd gen 4.0L
    1) The drain on the rad itself
    2)10mm brass bolt head easily found on the pass side of the engine, closer to the back of the motor
    3)10mm brass bolt head on the drivers side. This one is hard to see but is there, near the motor mount. It to the left side of the mount if looking at the engine from the drivers side.
    Note that the heater core isn't easily drained and some of the 2.5gal of coolant are in it, and a little is still left in other minor coolant lines. So weather you flush fully with water or only drain and fill with new coolant, you won't be able to add 2.5gal EXACTLY. There will still be a little bit of fluid in there, water if fully flushed, or old coolant if drain and filled only (not flushed with water).
