Radiator Flush
Discussion in '1st Gen. Tacomas (1995-2004)' started by Agabus, Sep 7, 2021.
  1. Sep 7, 2021 at 12:02 PM
    Agabus
    Agabus [OP] Active Member
    04 Tacoma TRD
    Unable to purchase radiator flush in this area. It's all gone. Shelves empty. From Walmart to O'reilly's to Advance Auto ect ect... Gone. Been waiting for weeks. Nobody knows anything about future stock.
    So... is there anything that could be made in the home lab that would do a fair job of cleaning out the system prior to putting in the Anti freeze?
  2. Sep 7, 2021 at 12:29 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    If your coolant has always been Extra long life there's no need for chemical flushes. Use distilled water, drain, refill, run, repeat until coolant is clear.
    Add 1 gallon full strength Asian extra long life and top off with distilled water.
    You end up with 50/50 mix because a bit over 1 gallon stays in system.
    Simple flush and fill
  3. Sep 7, 2021 at 12:37 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As mentioned above, distilled water.
    Cheap and easy.
    Agabus[OP] and Black DOG Lila like this.
  4. Sep 7, 2021 at 12:56 PM
    Agabus
    04 Tacoma TRD
    Not sure what was put in there last time, but it's still quite red. Will just flush fill flush fill....ect. Thanks!
    Black DOG Lila and Kwikvette like this.
  5. Sep 7, 2021 at 12:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Doesn't hurt to replace the thermostat; unsure on a 2.7 but on a 3.4, make sure you've got a deep socket!
    Also replace the radiator cap just to have all new components as well as fluid.
    And if you've got an auto, transmission fluid as well just because.
    Agabus[QUOTED][OP] likes this.
  6. Sep 7, 2021 at 1:08 PM
    Black DOG Lila
    Virginia
    Also fill the reservoir to the lower mark on it's side. When engine is at operating temp the level should rise to top mark and fall to bottom mark when engine has cooled.
    Agabus[OP] likes this.
  7. Sep 7, 2021 at 1:16 PM
    Agabus
    04 Tacoma TRD
    Been thinking about the thermostat. Just did the transmission and differential. All good!
  8. Sep 7, 2021 at 5:40 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    i have been using Calgon The stuff used in dish washers for years .
    Works great Cheap just heat and flush to clean water comes out.
    If your cooling system is not bad just plain distilled water .
