Radiator Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buckaroo1993, Jun 21, 2019.
  1. Jun 21, 2019 at 9:46 PM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    Can anyone tell me by these numbers what size radiator I have? Apparently Toyota decided to use about 4 different radiator sizes in 2003. F803993A-4571-4249-AAF0-9C20D67B1221.jpg
  2. Jun 21, 2019 at 10:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    22.5" between tanks since you have a V6 auto.
  3. Jun 21, 2019 at 10:06 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    Measure the height. There was 3 different made. Radiator for the 5vz was around 21". 3rz is about 20" and the 2rz being the smallest is around 18-19". Hope that helps.
  4. Jun 21, 2019 at 10:23 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Don't know about 412 but the other numbers have nothing to do with the size. PA66 is polyamide, aka nylon 66. GF25 means the nylon is 25% glass fiber reinforced. What the end caps are made of.
    As said, since you are v6 auto, you need the tallest size with the heat exchange lines for the trans (assuming you still want to run the stock heat exchanger for the trans).
    Edit: I used Denso 221-3138 with the OEM brackets. Auto 5VZ
    crazytacoman likes this.
  5. Jun 21, 2019 at 10:29 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Is that your truck in your profile pic?
  6. Jun 21, 2019 at 10:30 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yes. Has different wheels now though.
  7. Jun 21, 2019 at 10:32 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    That's something else! How high off the ground are you in that pic? o_O
    zero4[QUOTED] likes this.
  8. Jun 21, 2019 at 10:35 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    Read this.
  9. Jun 21, 2019 at 10:40 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    crazytacoman[QUOTED] likes this.
  10. Jun 21, 2019 at 10:46 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
  11. Jun 21, 2019 at 10:47 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    And stupid! :rofl:
  12. Jun 21, 2019 at 10:56 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    I would like to recreate this with like an absurd $3k&up suspension setup :D
