Radiator - High Temp Silicone Hoses
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Sep 20, 2021.
  1. Sep 20, 2021 at 1:48 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    Anyone know where to buy silicone radiator hoses for Taco Prerunner V6?
    Checked and none of auto parts have them or Rockauto, or Andys auto sport.
  2. Sep 20, 2021 at 1:51 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Sep 20, 2021 at 6:12 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Why?
    Most liquid cooled engines the coolant temperature is about 195*-205*. The basic black rubber radiator hose will last a very very long time.
    Of course, the high $$ silicone bright color hoses will get more "bro points".
  4. Sep 20, 2021 at 8:47 PM
    TacoBell07
    Four door 2wd Taco
    I want to replace radiator hoses and wanted get some silicone ones instead of the junk Oreily, Advance, auto zombie store sells. Anyone know any other brands besides HPS?
  5. Sep 21, 2021 at 4:58 AM
    sprucemica
    sprucemica 2013 DCLB Limited 4.0L 4x4 - Spruce Mica
    They really do look cool, though. It's like the TRD oil cap...just for looks really.
  6. Sep 21, 2021 at 3:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    blu92in99 and hemitruk like this.
  7. Sep 21, 2021 at 10:42 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have to ask, You did Torque the hose clamps didn’t you? :cool:
    BTW, thanks for the link.
    I had heard of these type hoses, just never knew much about them.
    Torspd[QUOTED] likes this.
  8. Sep 22, 2021 at 1:21 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Most radiator hoses are made of polyester (or similar) fiber-reinforced EPDM. Perfectly suitable for any car. Silicon hoses are just for the "cool" factor.
    That being said, probably eBay.
  9. Sep 22, 2021 at 9:29 PM
    TacoBell07
    Four door 2wd Taco
    HPS silicone hoses are good up to -65 to 350 F max.
    Gates hoses from auto parts store are 20-30 each for upper and lower etc and have these specs
    Temperature Rating: -40 F to 275 F (-40 C to 135 C) in coolant hose applications.
    So while silicone defiantly more durable it does not seem rise to level of being worth 100+ doll hairs.
    My only real concern is that my taco is an 07 and hoses are probably original from factory. How long might they take til they need replacement.
  10. Sep 22, 2021 at 10:46 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    You'll get 15+ years out of them unless there has been oil leaking on them. Just replace with OEM, unless you have a large budget or are thinking of further upgrades where silicone hoses might be worth your while. Easy way to tell is just to remove the top hose and give it a squeeze, check insides to see if any cracking or dry rotting. Personally, I'd run the OEM ones from initial install until one fails, then start replacing them. Of course, keep an eye on them at regular maintenance intervals.
    Knute and TnShooter like this.
  11. Sep 22, 2021 at 11:33 PM
    TnShooter
    Deogee
    STOCK
    My 07’ is still on OE hoses. I have almost 149k on it.
    TBH, I don’t see me replacing them until they look like they need to be replaced.
    Or they blow out. Which, is possible. But……. I am not always on t of my preventative maintenance either:eek:
    I’m good on oil changes and stuff. But the more involved the PM gets, the less likely I am to “get to it”.
    6 gearT444E likes this.
