radiator hole and catastrophic overheating without warning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paranoidale, Sep 30, 2017.
  1. Sep 30, 2017 at 5:52 AM
    paranoidale
    paranoidale [OP] New Member
    so, despite all the skid plates the 2014 will accept, i unknowingly poke a hole in the radiator. the check engine light pops on and the temp gauge drops to cold and rests on the needle peg. I drive home, 8 miles, to plug in the obd tester. safe to say it got HOT. Dealer says block is warped, $20,000 replacement. am i the only guy who thinks the gauge ought to show heat, whether there is water or not.
  2. Sep 30, 2017 at 5:57 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Wait, so you knew you had no coolant and drove 8 miles? What is wrong with you?
    DanoDavis, blu92in99 and koditten like this.
  3. Sep 30, 2017 at 6:00 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
  4. Sep 30, 2017 at 6:19 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    ^THIS
    ^^ALSO THIS!
    How on earth could you seriously think that driving home 8 miles without any coolant was a good idea? The temperature gauge is a WATER TEMPERATURE gauge, not an engine temperature gauge. It's like that on pretty much every vehicle that's ever existed (except for air cooled engines...).
    So first, accept that you did this to yourself and lets move on.
    Can you provide pictures of the damage? Skid plates offer protection from rocks and things that come from underneath. Typically, radiator punctures come from stuff that gets forced in through the grill. If you hit a large rock and broke your radiator I'd imagine the skid plate is 100% destroyed.
  5. Sep 30, 2017 at 6:26 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    20k lol. They must have 45 gallon barrels of lube at that dealer.
    Look for smashed tacoma for a heart transplant.
  6. Sep 30, 2017 at 6:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    Cast iron blocks don't warp.
    Aluminum heads do.
    Take it to a real mechanic.
    PS. Post pics of said hole/leak point. Bet it is in a location that has nothing to do with skid placement.
    DanoDavis and Bentrodder like this.
  7. Sep 30, 2017 at 6:32 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Why the hell would you drive a truck without coolant?? 20k for a motor swap, I've seen worse. Brand new 5.7 long block for a flooded tundra ran right around that area. Parts and labor. I'd look into a reman motor from jasper and swap that. I'd bet it would be around 5500 for a reman from jasper.
  8. Sep 30, 2017 at 6:34 AM
    AKTacoParty
    AKTacoParty Well-Known Member
    Jake
    Astoria, OR
    2013 DCLB
    885s, Dakars, Bilsteins, Allpro Sliders, Archive Garage Hammer Hangers, Wheelers Ubolt flip, super bumps, RCI front skid
    If it wasn't showing a temp that would mean the cooling system was completely dry or dry enough it couldn't circulate coolant. How much coolant came out when the radiator was damaged?
  9. Sep 30, 2017 at 6:34 AM
    replica9000
    2019 T4R ORP
    Now might be the time to do an LS swap. It would cost less than 20k :burnrubber:
    DanoDavis likes this.
  10. Sep 30, 2017 at 6:34 AM
    Bebop
    Nick
    I'm guessing somewhere between 2.5 to 3 gallons
  11. Sep 30, 2017 at 6:39 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    My guess from reading the OP is that he didn't realize it was a coolant leak til he got home. He just saw the CEL and gauge drop cold. At least that's what I got from the OP. Anyway, $20k for a motor is absurd.
    JayRolla likes this.
  12. Sep 30, 2017 at 6:41 AM
    replica9000
    2019 T4R ORP
    There's no "low coolant" idiot light on our trucks?
  13. Sep 30, 2017 at 6:43 AM
    AKTacoParty
    Jake
    Astoria, OR
    2013 DCLB
    What I mean is, was the leak a slight trickle, a garden hose, or hurricane Marie?
  14. Sep 30, 2017 at 6:49 AM
    paranoidale
    not my first rodeo, even an idiot knows to stop when overheating. my point is the truck's warning systems gave no indication that i was overheating. hot is hot, water or not.
    a stick made it's way through an inspection hole and bled all the water out. the dealer did offer a used motor for $11,000. don't know how the mechanic could guess a warped block. i gave it to them for a blown head gasket repair.
    my heat gauge didn't show cold, it completely shut down
  15. Sep 30, 2017 at 6:53 AM
    replica9000
    2019 T4R ORP
    If my coolant gauge went cold while driving, I'd stop to check the coolant. I believe the gauge starts to register at 100°F
  16. Sep 30, 2017 at 6:54 AM
    Bebop
    Nick
    Depending on his location 100 degrees could be ambient air temp
    Crow_of_judgement likes this.
  17. Sep 30, 2017 at 6:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    No. And there should be no need for one.
    blu92in99 likes this.
  18. Sep 30, 2017 at 6:57 AM
    Bebop
    Nick
    Yes!!!!!! Low coolant lights are for morons.
  19. Sep 30, 2017 at 6:58 AM
    replica9000
    2019 T4R ORP
    I agree. Usually idiot lights come on when it's too late. One of my old GM cars had one. It was the first light to come on after hitting a deer.
  20. Sep 30, 2017 at 6:58 AM
    Clearwater Bill
    Billy
    Largo Florida
    Re read post 8.
    You need a new mechanic.
