radiator hole and catastrophic overheating without warning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paranoidale, Sep 30, 2017.
  1. Sep 30, 2017 at 7:01 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Just for the record.....the GR engines are aluminum block and heads
    ItalynStylion likes this.
  2. Sep 30, 2017 at 7:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    My bad then. :anonymous:
    However, a warped block diagnosis w/o pulling a head is pretty much a stretch.
    And $20k is a rugged price.
  3. Sep 30, 2017 at 7:06 AM
    Plain Jane Taco
    USA
    Truth :thumbsup:
  4. Sep 30, 2017 at 7:06 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    In for the skid fail pics showing the weak point to the radiador. I hope you get this taken care of OP.
  5. Sep 30, 2017 at 7:09 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Temp sensor cannot read temps if not immersed in water/coolant. If the gauge drops to cold, you have a BIG problem and it needs to be shut down immediately. Been like that forever.
    It's one reason idiot lights for temps suck.
  6. Sep 30, 2017 at 7:49 AM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    No you are the only guy who thinks this. At work we say "no matter how much you idiot proof something they will always make a better idiot".
    The sensor measures the temperature of the coolant. The coolant transfers the heat of the engine to the coolant and then to the radiator and then to the air. A simple heat exchanger. Without the coolant as the heat transfer medium the system can not do its job and the motor well it can suffer all sorts of heat related issues as yours did.
    The actual sensor uses resistance to measure the temperature. At different temperatures the resistance changes which is what gets converted to a gauge reading. So a lack of coolant may have it drop and then rise as it gets some coolant or drop as it does get coolant. End result is they often go wonky jumping around before they stabilize again at whatever temperature the actual sensor is at. So while it says X temperature the motor has no coolant and is overheating. IT REQUIRES COOLANT TO READ ACCURATELY.
    Ignorance of how things work doesn't mean it isn't doing what it was designed to do.
    jberry813 and Plain Jane Taco like this.
  7. Sep 30, 2017 at 8:30 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Welcome to TW :notsure:
    DanoDavis and JoefromPTC like this.
