Radiator Hose clamps - Part #'s/Should I?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpencerTacoSC, Mar 28, 2025.
  1. Mar 28, 2025 at 4:00 PM
    SpencerTacoSC
    SpencerTacoSC [OP] Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    All right. I feel dumb because I can't find any threads answering this question, but.... I've got a slow drip-drip leak at the block side of the radiator hoses. Fine, no big deal. Truck's old enough to buy itself a beer, a hose or two going bad is hardly worth losing sleep over. However, I'm running myself in circles figuring out:
    A) Should I replace the hose clamps while I'm replacing the hoses? I lean towards "Yes, get it over with. They're damned cheap".
    B) What the hell is the part number? Yotashop says it's 90467-37005, but a few other parts websites only list that clamp for the 2nd and 3rd gen.
    Much appreciated.
  2. Mar 28, 2025 at 4:20 PM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    Never mind, found the things on a parts diagram at Partsouq...Oh well.
    Part # 90467-37005
    Gen1andDone likes this.
  3. Mar 28, 2025 at 5:41 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Lol...yes?
  4. Mar 28, 2025 at 5:49 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Spring clamps? You can re-use those as long as they're not rusty or deformed
  5. Mar 28, 2025 at 5:50 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    meh, probably shouldn't.....
  6. Mar 29, 2025 at 5:37 AM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    Partsouq has them for ~$3 each. The ones on the truck are probably fine, but fuck it. Peace of mind is worth $12.
  7. Mar 29, 2025 at 6:25 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Any reason you can't just use a quality stainless hose clamp, found locally?
  8. Mar 29, 2025 at 7:11 AM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    I've got no clue what the dimensions are, and I don't like worm gear clamps for radiator hoses. I'm sure they work fine if you install them properly, but I'm in a financial position where $25 (shipped) for all 4 replacement clamps is worth the peace of mind.
    Black97v6MT and Sparky 97Runner like this.
  9. Mar 29, 2025 at 2:51 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    And what were the part #'s?
  10. Mar 29, 2025 at 2:52 PM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    90467-37005
  11. Mar 29, 2025 at 3:10 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    It’s a no-brainer for most of us old farts. I change over to traditional hose clamps as soon as I can. I even started using the German style clamps - instead of holes they have ridges on the outside. They used to be quite pricey but have gone done in price.
  12. Mar 29, 2025 at 3:14 PM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Stay away from those worm clamps
    Your old constant tension clamps are likely ok
    Replace hose if the old hose has serious indentations of the old clamp
    I had a leaky upper hose some time ago
    What I found when I removed hose was an exceptional amount of cruddy build up under the hose where it mates to the metal
    Had to carefully razor blade it off and smooth it out.
    New OEM hose, same old clamp and weep free for years and over 100k miles
    Same thing happened with the lower hose a couple years after top hose
    Odds are your hose maybe also has this cruddy buildup that allows weepage underneath the clamp :notsure:
  13. Mar 29, 2025 at 4:04 PM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    It had that buildup. I wire-brushed it all off. Must have been sealing the old hose + its internal scale to the mating surface. Ah well. Lesson learned, new hoses ordered. I'll get out in front of it next time.
    Black97v6MT[QUOTED] likes this.
  14. Mar 29, 2025 at 4:11 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Is the lower hose doing the same?
  15. Mar 29, 2025 at 4:15 PM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    Lower had a bunch of white crud flake off and is the same age as the upper hose. It's not dripping yet, but I doubt it's far behind.
    Black97v6MT likes this.
