Radiator hose leak and coolant exchange
Discussion in '1st Gen. Tacomas (1995-2004)' started by boshak, Feb 7, 2012.
  1. Feb 7, 2012 at 10:38 AM
    boshak
    boshak [OP] Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    My upper radiator hose is leaking coolant... Coolant is a rust color. I've never done this type of work but have plenty of time to handle this. All recommendations are welcome - how to, other parts to check, where to purchase parts / fluid, tools needed, etc.
    Tacoma 3.4l v6
  2. Feb 7, 2012 at 10:49 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    I am searching to se if there is a thread with a how to for you to check out
  3. Feb 7, 2012 at 10:51 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Rust colored coolant isn't good.
  4. Feb 7, 2012 at 5:34 PM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    Before you drain the coolant, run the engine until the engine gets warm enough for the thermostat to open, then drain the coolant. That way all the coolant will drain out. Replace the hose.
    You may want to get a bottle of radiator flush and use it before you put in the new antifreeze. Make sure to follow the directions on the radiator flush.
    Always look for leaks after working on the cooling system, and make sure to keep an eye on the temp gauge when doing the radiator flush.
