Radiator Hose Life ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Sep 2, 2017.
  1. Sep 2, 2017 at 7:56 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The HPS hoses have a stronger construction than OEM. Multiple braides.
  2. Sep 2, 2017 at 7:57 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Haven't ever used the Gates hoses. If it is a multibraid, rather than a single, then they are a good investment.
  3. Sep 2, 2017 at 8:44 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    As has been pointed out, heater hoses tend to outlast radiator hoses. From 35 years DIY experience, I have ever had a heater hose rupture. I replace them if I happen to be replacing the heater core or they don't pass my visual inspection. I can only speculate heater hoses last longer because they tend to be thicker and don't go through as many hot/cold cycles as rad hoses.
    Currygoat likes this.
  4. Sep 3, 2017 at 4:36 AM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks guys - I drain and fill the radiator every 30K so in view of the opinions here I'll grasp and squeeze and seriously consider at 120K. Thanks again for all your input.
  5. Sep 3, 2017 at 9:25 AM
    scottfarm
    scottfarm Well-Known Member
    Florida
    tacoma 4X4
    aires 3D mats, scan gauge II, rear differential breather relocation, and bakflip G2 bed cover.
    Change them out at 200K with OEM and change out the radiator at the same time.
  6. Sep 3, 2017 at 9:28 AM
    george3
    New Jersey
    What gave you the inspiration to do so ? Did U grab something spongy or rubbery ?
  7. Sep 3, 2017 at 1:47 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    ive had them collapse on other brand cars when revving the engine. usually because a spring has broken inside.
  8. Sep 3, 2017 at 2:12 PM
    george3
    New Jersey
    This is all good information for TW members to keep in mind - learning from others experience is a great benefit of this forum.
  9. Sep 3, 2017 at 2:15 PM
    george3
    New Jersey
    I just noticed on you signature - 300K - congratulations - I'm sure we could all learn a thing or two from you.
