Radiator life
Discussion in '1st Gen. Tacomas (1995-2004)' started by Larrys 02 Tacoma, Feb 21, 2016.
  1. Feb 21, 2016 at 4:10 PM
    Larrys 02 Tacoma
    Larrys 02 Tacoma [OP] Member
    Lawrence
    Santa Maria, CA
    02 Prerunner Stnd Cab
    I have a 02 Pre-runner 2.7L, auto, standard cab. It has 143,XXX miles on it. The radiator looks fine and I've maintained the coolant changes since I bought it in 08 with 98,XXX miles on it. The radiator is 14 years old, how much longer can I expect it to last? With the aluminum head, I'd sure hate to be on a trip and have it fail and ruin something. Was thinking of replacing it as preventative maintenance. What says you guys? Also was thinking of genuine Toyota radiator for replacement. Do the plastic tanks on these turn color before they fail?
  2. Feb 21, 2016 at 4:24 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    though mine is a 3.4, mine lasted 265k before it crack on the top plastic portion of the radiator.
  3. Feb 21, 2016 at 4:30 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    If you are worried, have it pressure tested, if it passes, worry about stuff like herds of buffalo running into your Taco instead.
  4. Feb 21, 2016 at 4:45 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    The only thing to worry about is the famous pink milkshake. They are easy to replace, and helps with peace of mind that you won't destroy the transmission.
  5. Feb 21, 2016 at 5:47 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I just replaced my (3.4l) radiator after 220,000 miles. It was VERY lightly weeping at the top, and I ran it like that for 6 months before replacing. They are generally very good, I wouldn't bother with it until you see something amiss. Get a genuine Toyota, most of the other ones have slight fitment issues and many are questionable quality.
  6. Feb 21, 2016 at 5:51 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    I got 200k before I got the common crack on the top plastic. I wouldn't worry much till then
  7. Feb 21, 2016 at 6:01 PM
    1988Mercedes
    1988Mercedes Well-Known Member
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    180,000 on mine. Stress cracks in front of the top hose inlet.
  8. Feb 22, 2016 at 7:40 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Around 230K when the top plastic piece developed a crack where the radiator hose clamps on.
  9. Feb 22, 2016 at 6:32 PM
    Larrys 02 Tacoma
    Lawrence
    Santa Maria, CA
    Thanks for all the responses! I'll just wait awhile and keep an eye on things. Going to do a drain of the coolant and refill as it about time to do it.
  10. Feb 22, 2016 at 7:16 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    saying that, if you have tranny cooler embedded inside radiator, replace it at ten years
    whether or not you have problems or it looks brand new
    200-250 for a new rad is better than >1800 tranny rebuild
    I ignored this advice and at 13years, ...blorp....
  11. Feb 23, 2016 at 8:39 AM
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    02 Double Cab 3.4L replace ti at 152K leaking at top. Son had truck for 18mos and had put use mismatched tire on front. I feel the vibration and need for new shock probably caused it. Got new one at NAPA for $165 was an easy job compared to replace the radiator in our 04 Expedition which I had done.
  12. Feb 23, 2016 at 3:36 PM
    JPinFL
    Yeah...it's a pretty easy job. I got one from Pepboys for around $120. Perfect fit. Went to dealership for Toyota brand coolant.
    No issues so far.
  13. Feb 23, 2016 at 4:40 PM
    Larrys 02 Tacoma
    Lawrence
    Santa Maria, CA
    Isn't the Dex-Cool coolant acceptable for Toyotas? I don't doubt that the genuine product is better, but always thought the "Orange" stuff was good enough.
  14. Feb 23, 2016 at 7:02 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Maybe, but use what it calls for and you will never go wrong.
