Radiator petcock 2.7 ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Sep 21, 2010.
  1. Sep 21, 2010 at 2:55 PM
    george3
    george3 [OP] Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I fully expect to be ripped on this one but here it goes. Dumb question but where is the Radiator petcock on the 2.7 ? Do I have to remove the skid plate ? It's usually on the drivers side. I want to drain the antifreeze in the radiator and refill it. Easy job, but not for me. Any help for a visually impaired DIY appreciated. Links and or pics would be great. Thanks. Curious George.
  2. Sep 21, 2010 at 3:58 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Man .... got finally got me thinking ..... went out .... popped the hood .... looked about ..... my guess is that you are going have to remove the fan shroud .... which of course has the radiator overfill attached.
    Best of luck.
  3. Sep 21, 2010 at 4:43 PM
    george3
    new jersey
    tacoma
    Thanks for the reply. I sure hope there is a easy way. Somebody must have done this. Join in por favor.
  4. Sep 23, 2010 at 3:02 PM
    george3
    new jersey
    tacoma
    Has anyone been able to turn the petcock with out removing the fan shroud ? If so how ? What tool did you use ? I was thinking I could put some tubing on the outlet and drain it without a mess.
  5. Sep 23, 2010 at 6:12 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    I can on my 05 with no problems at all. No clearance issues or anything hindering the petcock on the radiator.
    Now if you really want to get rid of some fluid just pull a lower hose its a fast method of draining and if you have a small lift or some good jacks get a 3 gallon bucket and collect the fluid so the EPA idiots don't get aggravated.
  6. Sep 24, 2010 at 1:42 AM
    george3
    new jersey
    tacoma
    Thanks for the reply. Maybe I just have large hands but that couldn't be because I don't have a large member or maybe I got short changed. :rolleyes:
    What do you do with the collected fluid take it to Washington and drop it off at the EPA ?:confused:
  7. Sep 24, 2010 at 6:10 AM
    2.7taco
    Texas
    No I just take it to a local shop and drop it off. If I took it to Washington you would find me on the news. :D
    According to the EPA you should collect it and have it recycled.
  8. Sep 24, 2010 at 7:39 AM
    TampaDude
    TampaDude Well-Known Member
    Riverview, FL
    '06 Silver 5-Lug Access Cab
    So...flushing it down the toilet is a no-no??? ;)
  9. Sep 24, 2010 at 2:43 PM
    george3
    new jersey
    tacoma
    I was wondering about that too tho U R being :rolleyes: sarcastic maybe. I bet a lot of people flush paint down the toilet now that it is water clean up.
  10. Sep 24, 2010 at 9:31 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I drained my radiator and the block a few weeks ago. Took some pics but haven't had time to post them yet. The radiator drain is on the drivers side. I didn't have to remove anything, but I don't have a skid plate. The engine block drain is on the passenger side just below the exhaust headers. I think it's brass and it sticks out like a sideways L from the engine block so it should stand out. I used 1/4" vinyl tubing to attack to both of the drains. Then put the other ends in a couple of empty washer fluid jugs, took off the radiator cap, opened the drains there you go. Draining the reservoir was a little difficult as it has a rubber plug with a spring clamp on it. The clamp comes off easy, but since there's no valve once you remove the plug, out comes all the fluid.
    Hope this helps, maybe I'll post my pics this weekend.
  11. Sep 24, 2010 at 10:03 PM
    george3
    new jersey
    tacoma
    Thanks. This is great. Please do post the pics. I would appreciate it and I'm sure it will help others on TW.
