Radiator pin-hole leaks -
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Dec 28, 2022.
  1. Dec 28, 2022 at 4:14 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    If T-stat doesn't work/open it won't allow coolant to pump to heater core properly.
  2. Dec 28, 2022 at 4:24 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    @na8rboy You are correct in that statement. I was referring to his situation. He said, “At the house opened up while engine running didn't spy anything fantastic - temp dropped to normal range pretty quick.” If his thermostat was stuck closed, the temps would stay high. Maybe he misspoke, or I misunderstand something.
  3. Dec 28, 2022 at 4:33 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Regardless, it's easy to gain access to the thermostat once the radiator is pulled anyways. Probably wouldn't hurt to replace the thermostat when replacing the radiator that's leaking. And definitely flush the system and heater core.
  4. Dec 28, 2022 at 4:33 PM
    na8rboy
    WI
    Unless he's has an air locked in system it would drop opening rad cap. We are both on right track here. Without being right there, it's a crap shoot diagnosing...lol
  5. Dec 28, 2022 at 4:39 PM
    2021SR5V64WD
    2021SR5V64WD [OP] Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I probably misspoke - I am not by any stretch of the imagination a car-engine-dude. Give me a SQL Server and/or a spreadsheet full of numbers and I'll
    whip that sh*t around like nobody's business - cars... tools... ummmm no.
    Chuy[QUOTED] likes this.
  6. Dec 28, 2022 at 8:40 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    You have air in your heater, common when you run low on coolant.
    Just replace the radiator and call it a day.
    Better to spend a few dollars on a proper repair than damaging the car by running low on coolant and overheating. Replacing the car will be a lot more expensive than the radiator.
    You probably have a friend who could replace it for food & a couple of beers.
    Good luck.
