Radiator repair
Discussion in 'Technical Chat' started by Capone, May 1, 2018.
  1. May 1, 2018 at 7:40 PM
    Capone
    Capone [OP] Active Member
    Kathy
    Savannah.Georgia
    Toyota Tacoma 97 2.4 200,000miles
    Can you repair a radiator,up to with fiberglass?
  2. May 2, 2018 at 12:32 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have used plastic weld as a emergency repair on the plastic tanks.
    It seems to crack in a few days .because the different materials expand and contract at different rates
    Maybe some one has a sure fire method .
    Might be time to consider new
    Capone[OP] likes this.
  3. May 2, 2018 at 10:39 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    when radiators were entirely metal some places would fix small leaks by putting a bead of solder over the hole. now a days though since they are made from more then 1 material its not a common practice, radiators are not horribly expensive so I would just replace it for peace of mind. Denso would likely be OEM, Ive used NAPA uses before with no problems, if money is a concern you could try Pull-a-Part but your tacoma is older so it may be hard to find one at P-a-P.
  4. May 23, 2018 at 7:38 PM
    Capone
    Kathy
    Savannah.Georgia
    Thanks for the help! Bought a new radiator
