Radiator suggestions for '04, v6, auto trans, prerunner, 2wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by veleno, Jul 24, 2024.
  1. Jul 24, 2024 at 1:06 AM
    veleno
    veleno [OP] Well-Known Member
    I used the search and found some threads but nothing specifically answering my question.
    I need to replace my radiator in my '04, v6, auto trans, prerunner, 2wd. Looking through RA I come across a couple, but the ones I'm looking at are:
    TYC 1755 (core dimensions are correct) - Lifetime warranty
    Denso 2213138 (core height/width dimensions are wrong, however, if you switch them around they're correct, so I'm not sure if it was a typo?) - 12mo warranty
    Can anyone confirm which one fits or which one is better?
    Is there another brand I should look into?
    Thanks in advance for any help!
  2. Jul 24, 2024 at 5:20 PM
    hessian42
    hessian42 Well-Known Member
    Max
    very happy with my Koyorad from rockauto. over 2 years on it with zero issues!
  3. Jul 28, 2024 at 4:18 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I purchased a car quest premium radiator from advance auto parts. I've had it on the truck since June 2021 and I've had zero issues with it. Lifetime warranty, so if it goes bad I can get a replacement at my local parts store.
  4. Jul 28, 2024 at 4:28 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    I always go Denso when possible. You probably won't need to tweak anything to make it fit. Frankly the 'best' options for radiators on these is a bit limited at this point. No decent all aluminum ones and not much available that is close to OE.
    Nessal likes this.
