Radiator Support Bushing PNs and How to Replace them
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Apr 14, 2025.
  1. Apr 16, 2025 at 10:06 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yea, was noticeable right away in normal everyday driving. I could feel the difference when turning and braking. More solid feel and a lot quieter. I was surprised how much of the creaks and rattles went away. The cab must have been shifting around.
  2. Apr 16, 2025 at 6:53 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    Mine too. Totally worth doing.
    I was a genius at first and replaced all the nuts with OReilly nuts which are not prevailing torque nuts. I caught it after a couple drives.
