Radiator
Discussion in '1st Gen. Tacomas (1995-2004)' started by 06texasedition, Jun 2, 2013.
  1. Jun 2, 2013 at 1:35 PM
    06texasedition
    06texasedition [OP] Well-Known Member
    Picayune ms
    06 Tacoma Texas edition(RIP) 14 tundra limited 4x4
    3" rough country lift. Blue interior lights courtesy of jumper led. Led tail lights avid front and rear bumper guard with 4 Hellas on front. Borla dual exhaust blue led reverse lights color matched satoshi grille
    Can anybody tell me if I need the 20 and 3/4 or 22 5/8 without me having to pull the radiator for a 97 v6 4wd
  2. Jun 2, 2013 at 3:19 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    When i replaced mine it was a 22 5/8 unit.. im a 95.5 so we could be the same..
    The rad is for auto or manual transmissions..
  3. Jun 2, 2013 at 3:29 PM
    06texasedition
    Picayune ms
    I took it out n brought it to auto zone mine was 20 3/4 for manual
  4. Jun 2, 2013 at 3:34 PM
    hayabusa3303
    florence sc
    95.5 taco 4x4
    Mine is a manual too why are there changes like that... humm..
    Not unless a cold weather package is different... Mine has it on there...
  5. Jun 2, 2013 at 3:58 PM
    Dirty Pool
    Dirty Pool HOUSE OF BLUE LIGHTS
    59.4 Miles, 56.67*NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, Both 31" MTZ's and 33" Toyo's, 01 Center console, Map lights, Disraeli gears
    Radiator for auto trans has extra space for internal trans cooler (in the bottom tank), manual trans does not and is shorter.
  6. Jun 2, 2013 at 4:46 PM
    hayabusa3303
    florence sc
    95.5 taco 4x4
    When i think about that rad it did have ports on it but they where NEVER used blocked off... Maybe they ran out of rads for manuals when making mine and put a auto one in.. :confused:
  7. Jun 2, 2013 at 6:54 PM
    06texasedition
    Picayune ms
    Mine had the tubes for auto they told me at autozone that they only make 1 for both auto and manual. We measured it at autozone and its working fine
  8. Jun 3, 2013 at 6:25 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    It's Autozone that sells just one. There are 3 different size radiators for Tacomas depending if 2wd, auto or manual. All 3 can be had aftermarket. In the aftermarket world sometimes the 4wd units will interchange as a "bolt in" sometimes they will not. In some cases the fan shroud will not fit correctly but can be modified.
    If one has a manual, the man trans radiator is desirable due to the significant approach angle possible. A front skid can then slant back directly from the front mount back instead of having the huge rock magnet of the OEM/Bud Built type front profile.
    Some folks with autos have been known to swap in the shorter radiator and use a stand alone trans cooler just to get this benefit. Then there is the issue of the auto cooler tubes inside the radiator failing and potentially destroying the trans in the process.
  9. Jun 3, 2013 at 7:25 AM
    06texasedition
    Picayune ms
    Yea I had to get a radiator ASAP and autozone had it so I got it. It's running fine drove 60 miles to work this morning wit no problem. As for skid plate I don't have one I lost em mud riding lol thanks for the info
  10. Jun 3, 2013 at 7:29 AM
    06texasedition
    Picayune ms
    I would have ordered from rock auto if I cld have waited
