Radio and Amp not working
Discussion in 'Audio & Video' started by Gonzo1982, Aug 10, 2019.
  1. Aug 11, 2019 at 9:42 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's really stupid. Why would that even be a thing on these radios? All they should ever have is power, ground, and a built in fuse in the back of the HU as a just in case thing. To add a micro reset button I feel is incredibly redundant.
  2. Aug 11, 2019 at 9:55 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Maybe the unit went into anti-theft mode and the code needs to be reset?
  3. Aug 11, 2019 at 11:20 AM
    Gonzo1982
    Gonzo1982 [OP] Well-Known Member
    Tullahoma, TN
    2013 MG DCLB TRD Sport
    5100, OME 885, 1.5” Icon AAL, KO2 275/75/17
    Manual doesn’t say anything of it. These units don’t have a removable faceplate. Screen is built in and isn’t removable. Guess I’m resorting to taking to the installer
  4. Aug 12, 2019 at 12:58 PM
    Gonzo1982
    Tullahoma, TN
    Turns out it was the 7.5amp fuse under the hood that was for the ODB port. Go figure.
    Shelf Life likes this.
  5. Aug 12, 2019 at 1:28 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    It would’ve taken me forever to figure that out so don’t feel bad. I was “half” right, just for the wrong reason. I knew the RR module wasn’t communicating with the CAN-BUS, but I was assuming the issue was in the module, not the can-bus. I’m sticking this problem in the file in case it ever happens again
  6. Aug 12, 2019 at 1:30 PM
    Gonzo1982
    Tullahoma, TN
    I can't take credit, my installer found it, but all he did was check the obvious and then start pulling fuses till he found one. So next time, I'm just going to check the obvious and then start pulling lol.
  7. Aug 12, 2019 at 1:48 PM
    81shark
    81shark Well-Known Member
    That is so weird considering you said there was power at the stereo harness
  8. Aug 12, 2019 at 2:13 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I think he just checked the constant 12v (yellow) and didn’t know to check accy power. Easily overlooked if you’re not super familiar with doing stereos. Props to OP for being willing to pull out the radio and use a meter instead of running straight to the installer. If I had a dollar for every fix I did where it was just a blown radio fuse, I would have a few hundred dollars lol
