Radio and gauge dims hitting breaks
Discussion in 'General Tacoma Talk' started by Alan2015, May 23, 2023.
  1. May 23, 2023 at 4:27 AM
    Alan2015
    Alan2015 [OP] New Member
    Alan
    Dim dash and gauge
    2015 Toyota Tacoma crew cab
    Hello I have a 2015 toyota Tacoma crew cab, Notice my radio and mileage Gauge dims when I apply the breaks . I have changed bulbs back to the stock still have the issue and when I turn lights my Abs and other light light up on dash. It comes and goes. I have YouTube the issues can’t find the problem. Been told it’s the headlight switch and cluster. Any tips on what’s causing this?
    thanks
  2. May 23, 2023 at 9:12 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like you either have an issue with one of your tail light assemblies or a bad ground to one of them causing power to backfeed.
    Bivouac likes this.
  3. May 29, 2023 at 9:22 AM
    Alan2015.
    Alan2015. New Member
    Alan
    Brake lights and gauges dim when I apply brakes and sometimes abs light comes on and blinkers sometimes works.
    Could it be the Curt wiring harness? I have notice also my blinkers works half the time now if I hold my breaks then use blinker it works with no issue. And when I turn in my headlights switch someone ABS lights come on but I turn everything off then crank back on it off I’m at a lost thinking it has something to do with the Curt wiring harness
    Bivouac likes this.
  4. May 29, 2023 at 9:24 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Start simple. Clean and tighten the grounds. Bad grounds can cause some strange effects.
  5. May 29, 2023 at 12:35 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    if you have the 4 pin plug for trailer lights.
    Those evil converter boxes cause many light problems .
    Dm93 likes this.
  6. May 30, 2023 at 7:12 PM
    Alan2015.
    Alan
    Ok I have fix the dimming on the radio but today I couldn’t get it out of gear. I have replace the brake light switch now only goes into gear with the lights on. I’m lost
  7. Jun 1, 2023 at 4:10 AM
    Alan2015.
    Alan
    I have fix the issue. It was trailer lights, the box was extremely warm I haven’t use them in a while. I unplug instant after replacing couple fuses.
