Radio cutting out intermittently
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChadVKealey, Nov 28, 2017.
  1. Nov 28, 2017 at 10:22 AM
    ChadVKealey
    ChadVKealey [OP] Well-Known Member
    Philadelphia, PA
    2017 Silver Sky Tacoma SR5
    None (yet)
    Over the last 3 or 4 weeks, the stereo ("Premium" but not "JBL") in my truck has been cutting out/shutting off at what seems like very random times. Once it was when I activated the right-hand turn signal while sitting still at a traffic light. It's also happened a couple of times during hard acceleration (e.g.: merging onto the highway) or when shifting into reverse. However, I can't find any way to reliably replicate the problem.
    When I say "cutting out", I mean it acts like it was turned off. If I press the power button, it'll come back on just fine (it takes 30 seconds or so, but considering it's booting up an OS, that's understandable).
    My first thought was a bad ground, but that seems unlikely given the age (I've had it 10 months and about 6,400 miles). The frustrating part is that I'm sure the dealer will say they can't do anything since it can't be reproduced (which I totally get; I've worked in tech support long enough to know that that's true).
    I did some searching on the web but can't find anything specific to 3rd gens. Anyone else seen or heard of this issue? Anyone know if the radio cutting out like that would trigger something that could be pulled from the computer (not sure what actually gets logged in there).
    Catfish21 likes this.
  2. Nov 28, 2017 at 11:05 AM
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    mine cuts in and out too. what the fuck...
    silver sky 17' 10k mi. purchased in jul
  3. Nov 28, 2017 at 11:08 AM
    ChadVKealey
    Philadelphia, PA
    None (yet)
    Hrm...mine is Silver Sky as well. Maybe they gave them all the bad radios.
  4. Nov 28, 2017 at 11:44 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
  5. Nov 28, 2017 at 12:37 PM
    ChadVKealey
    Philadelphia, PA
    None (yet)
  6. Nov 28, 2017 at 12:43 PM
    over60
    Muskoka, Ontario
    OOps, sorry... off to the dealer I guess.
  7. Nov 28, 2017 at 12:47 PM
    ChadVKealey
    Philadelphia, PA
    None (yet)
    It'll be due for its 6-month service in January, so I'll have them check it out then. It's not frequent enough to be annoying...yet.
    over60[QUOTED] likes this.
  8. Nov 28, 2017 at 3:36 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Our work Tundra did this the other day. I was taking a boat to the ramp for a test run. While backing the boat down the ramp the radio shut down. I didnt think anything of it, but then after the run, pulling the boat out of the water it did it again. Parked the truck, got out to secure everything and heard it shut down again. Once I got away from the launch area it has not done it again. Not sure what to think of that.
    I know this doesn't help your situation, but it tells me it is not specific to a certain model truck. Could be an Entune software issue.
    MOC221_ likes this.
  9. Nov 28, 2017 at 5:05 PM
    itsmermf
    itsmermf Well-Known Member
    Robert
    Merritt Island, FL
    2017 Tacoma TRD PRO
    Interior LEDs, all weather mats, TRD performance CAI, trifold hard tonneau cover, predator pro step, accessory interior/exterior illumination package. Kicker tweeters, Kicker speakers.
    Mine just did it it twice in 3 days, both times, when I was adjusting the climate control....
  10. Nov 13, 2020 at 2:36 PM
    Ccoppola
    Ccoppola Member
    2020 Tacoma TRD Sport Voodoo Blue
    Stock
    Did anyone get resolution on why radio cuts out?
    My seems to do it after receiving a text message or email thru the head unit
  11. Nov 14, 2020 at 7:15 AM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    My 2020 Pro radio cuts out every once in a while while playing Bluetooth. It almost always happens soon after I start the truck and drive off.
  12. Nov 14, 2020 at 9:03 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    I had random reboots on my '17 TRD headunit, went through all the checks with phone, software updates etc...
    Turned out to be that the microSd flash card for the map was crapping out at random times,
    to confirm I just popped out the SD card and the radio never rebooted after that.
    New map card and not one reboot either.
    Real easy test for the 16-19 radios...
  13. Jan 20, 2021 at 10:43 AM
    Spfx99
    Spfx99 Well-Known Member
    2019 Tacoma TRD PRO
    Mine was random at first then started to happen at the same location every day, and continue to reboot every 2 mnutes. So, I removed the sd card after the first reboot. No issues since.
  14. Jan 20, 2021 at 10:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Try the H/U firmware update posted in @ktbell444 's thread.
    ktbell444 likes this.
  15. Jan 20, 2021 at 12:17 PM
    Spfx99
    2019 Tacoma TRD PRO
    I already had updated it, Toyota even replaced the headunit. The only fix was to change SD cards.
    tonered likes this.
  16. Jan 20, 2021 at 12:22 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Change or permanently remove? I have been thinking about updating the map data, but I really don't see much value in it.
  17. Jan 20, 2021 at 12:27 PM
    Spfx99
    2019 Tacoma TRD PRO
    Change, my sd card is corrupt. You can permanently remove it but you will loose your compass in the dash. I'm going to try and get Toyota to replace under warranty, just haven't heard back from them yet.
  18. Jan 20, 2021 at 12:29 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good stuff.
    Yup. The card is the map data. I have put it to use maybe twice. Works okay enough, but it ain't no Google, Gaia, etc.
