Radio dimmer connection?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sleepy4x4, Jun 26, 2023.
  1. Jun 26, 2023 at 7:37 PM
    sleepy4x4
    sleepy4x4 [OP] Member
    Ric
    2008 TRD Sport Dbl Cab
    Anyone know where to connect the dimmer wire from an aftermarket Head unit so the display dims with the dash light knob on the Dash?
  2. Jun 26, 2023 at 7:54 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    Did you get a harness adapter or are you cutting the factory harness? With the adapter harness, it’s the orange wire in the harness adapter.
  3. Jun 26, 2023 at 8:02 PM
    sleepy4x4
    Ric
    I got an adapter, I will look at it better for the orange wire.
    Thanks
  4. Jun 26, 2023 at 8:04 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Depends which radio you had (JBL or non JBL) but Illumination + is going to be a green wire and Illumination - is going to be a Brown/White Wire.
    Just a note Toyota controls illumination brightness on the Ground side, Power side receives full battery voltage when the lights are on.
  5. Jun 26, 2023 at 8:18 PM
    sleepy4x4
    Ric
    Original was a JBL, I will look at the file set, thanks
  6. Jun 26, 2023 at 8:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I believe one of the first diagnosis I helped with here on TW was due to a blown dimmer.
    I think @Jimmyh might remember that one, I think there is a wire you don’t use on Toyota.
    Or at least not on some units. If the dimmer blows, it will send full brightness to all the gauges. You can’t adjust the brightness. It was a weird case, I learned something anyways.
    Dm93 likes this.
  7. Jun 26, 2023 at 8:32 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Depends on the radio but alot of aftermarket radios simply use a switched 12v input to trigger it to dim the screen and don't do variable dimming.
    TnShooter[QUOTED] likes this.
  8. Jun 26, 2023 at 8:54 PM
    TnShooter
    Deogee
    STOCK
    I have no idea.
    I was more interested in the diagnosis.
    I figured blowing the dimmer would have caused no lights.
    But it was just the opposite, full brightness.
    We finally figured it out.
    The original complaint was not being able to dim the lights.
    It had nothing to do with a radio, but that is what caused it.
    Guy bought the truck that way. iIRC
  9. Jun 27, 2023 at 4:47 AM
    caribe makaira
    Caribbean, Puerto Rico
