Radio Display Unreadable
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bassinman, Jul 29, 2012.
  1. Jul 29, 2012 at 8:54 AM
    bassinman
    bassinman [OP] Well-Known Member
    Gilbert Arizona
    11 Prerunner SR5
    Tint, WeatherTech mats, Differential Breather Mod, Fogs on anytime mod, Seatbelt chime disabled, glove box led's, Rear spring TSB
    Searched, but unable to find anything close. Have a 2010 with standard radio/CD. The radio display is absolutely unreadable during daylight hours (unless I turn headlights on). Is there any mod short of replacing the factory radio to get more brightness out of the display? Note: I'm an old guy but my vision is excellent!!!!! Display is just not bright enough!!!!!
  2. Jul 29, 2012 at 8:56 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    when you turn the headlights on the display dims, so that doesn't make sense.... did you try turning up your cluster display? that does the stereo too I believe.
  3. Jul 29, 2012 at 8:57 AM
    TacPro45
    TacPro45 Well-Known Member
    '11 TRD Sport Double Cab Long Bed
    Weathertech Floor Liners
    Try the dimmer switch on the dash? Although that wouldn't help you see the letters. I have trouble seeing mine with polarized sunglasses on...
  4. Jul 29, 2012 at 9:48 AM
    bassinman
    Gilbert Arizona
    11 Prerunner SR5
    Dimmer switch has no effect on radio display. Turning on headlights lights up display with different bulbs. Dimmer only affects intensity when lights are on. Agree with TacPro45 that polarized glasses make situation worse, but even without glasses display is so dim as to be unreadable.
