Radio doesn't work when i take out stock subwoofer?
Discussion in 'Audio & Video' started by Fize, Mar 20, 2010.
  1. Mar 20, 2010 at 8:23 AM
    Fize
    Fize [OP] Well-Known Member
    Andrew
    Yorba Linda
    2010 Tacoma Prerunner TRD Sport
    33" GT Adventuros M/T, 16" black steel wheels, 3" Toytec lift, 20% Tint, K&N Drop in Air Filter, Magnaflow Exhaust, Custom sub box, 2 12" Pioneer Premiers,
    Im building a custom box for my sub woofers for my 2010 double cab tacoma. I removed the stock sub behind the back seating, and when i remove the wiring from it, my radio doesn't work. No sound comes out, and I cannot even see the volume adjuster when I twist the knob. Anyone else have this problem? Do i need to rewire something? lmk
  2. Mar 20, 2010 at 9:03 AM
    zanodave
    zanodave Well-Known Member
    so il
    07speedwayblue
    My radio did not play when I unhooked the factory sub,however i think that the plug that you remove is to the factory amp. I replaced HU,front door speakers, sub,and added an amp so it did not matter in my case.
  3. Mar 20, 2010 at 9:27 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Alil off topic, but are you building a box for your stock subs? Or you have different subs?
  4. Mar 20, 2010 at 6:23 PM
    Fize
    Andrew
    Yorba Linda
    im building a box for new subs haha
    why would i use the stock sub?
  5. Mar 20, 2010 at 6:24 PM
    Fize
    Andrew
    Yorba Linda
    Ya im going to be using a new amp, so will i be able to just connect it to it and power hte speakers through the new one? will i also need an amp bypass?
  6. Mar 22, 2010 at 10:21 AM
    EGtaco
    EGtaco Well-Known Member
    2009 Tacoma
    I think if you remove the sub you may have meesed up the wiring to the facotry amp. When I had someone work on my truck they took the sub out and tried to bypass the factory ampo but same results no sound. They had to reinstall thte factory amp and rewire the new sub and amp. Since then I pulled the factory amp out and replaced it with a "real" amp.
