Radio Install Help? Radio and Dome light do not work
Discussion in '1st Gen. Tacomas (1995-2004)' started by sambo9, Jun 28, 2013.
  1. Jun 28, 2013 at 5:41 PM
    sambo9
    sambo9 [OP] New Member
    Went to go install an aftermarket pioneer deck into my stock 2003 tacoma regular cab. Had the factory radio in it, and it had never been changed before. I took it all apart, and first wanted to test the new deck to make sure i had all the connections right. I got all my install stuff from crutchfield and i had to the proper diagrams and wires connected.
    I twisted to wires together for the test run, hooked up the battery, new radio turns on, but every time i hit a button on it, it just powers off.
    + and - wires touched together, i hear a zap. I break it all down, now factory radio and dome light both don't work.
    I need some help... suggestions?
  2. Jun 28, 2013 at 6:52 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    it is either (a) a band ground issue or (b) more than likely a bad fuse. A bad fuse means no accessory power but the fuse probably didn't pop all the way and is getting a very tiny power arc in the fuse. That's why it turns on but dies as soon as you press a button. This can cause major damage to your electrical. Find and replace fuse and double check you have a solid ground. Both should be fixed. It either your 'radio' fuse or 'accessory' fuse or both
  3. Jun 29, 2013 at 4:35 AM
    sambo9
    turns out it was the 15 amp dome fuse under the hood, thanks for the help
