Radio Interference from LED bars
Discussion in 'Technical Chat' started by tntacomaguy, Jun 9, 2016.
  1. Jun 9, 2016 at 12:14 PM
    tntacomaguy
    tntacomaguy [OP] Well-Known Member
    I tried searching and couldn't find what I needed.
    I have 3 bars on the front of my truck. 1 20" and 2 6". I have separate switches for the 20 inch and the 2 6 inch ones are switched together. When I have my radio playing and turn on the 2 6inch lights several channels get major interference. This does not happen with the 20 inch bar. Both are wired exactly the same and switched the same, switches are in same location.
    What could be causing the interference and what needs to be done to fix it? Its annoying as anything :frusty:
    BTW truck is 02 Xtracab 3.4 TRD 4x4
  2. Jun 9, 2016 at 2:15 PM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Can you explain interference? Loss of power, static, etc?
  3. Jun 9, 2016 at 3:00 PM
    tntacomaguy
    Static ... Station plays fine until I switch on the lights then total static
  4. Jun 9, 2016 at 4:49 PM
    Revelations
    2014 MGM DCSB
    Does the same thing happen if you listen to a cd?
  5. Jun 9, 2016 at 6:55 PM
    tntacomaguy
    I'll have to check tomorrow. I kinda doubt it tho. Doesn't do it on all radio stations. Driving home this evening had one station on and flipped the switch and went to static. Another station was decent but still had some static
  6. Jun 9, 2016 at 9:07 PM
    Revelations
    2014 MGM DCSB
    My suggestion is to move your switch wires, specifically the ground wires. I'm not sure how you have your wiring set up tho. Do all the switches share the same ground point?
  7. Jun 11, 2016 at 6:07 PM
    tntacomaguy
    Cd plays fine. Same ground point is used for both switches
  8. Jun 12, 2016 at 1:51 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do you get the power from the battery or are you pulling it from the fuse block ??
    Same circuit as the radio ??
    For some reason the 6" Led lights are generating interference on the frequency of those stations
    Another vehicle parked next to yours do they get the same interference on the same stations ??
    Have you talked to the manufacture of the light bars in question ??
    It might be a common issue they might have a filter kit to fix the issue.
  9. Jun 12, 2016 at 2:11 AM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    The Light bars draw enough amperage to create a large magnetic field around the wire(s) running to and from your switches. Since DC does not have a frequency, the distortion is most likely caused by the magnetic field distorting a signal wire going to your radio.
    Solution: move the wires. If it is only causing distortion while you are listening to the radio, it is most likely interfering with the antenna signal. If it is anytime, then it is interfering with the audio out (speaker signal)
    deanosaurus likes this.
  10. Jun 12, 2016 at 11:10 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Straight DC won't create interference. The light bars probably have some kind of switching circuit to lower the voltage to the leds. That will cause radio interference without careful design and installation. Moving the wires might be the solution. Sometimes the interference is conducted--the noise is carried into the receiver, amplifier, or whatever on the power and/or ground lines. The fix there is in the power and ground connections and electrical filtering. It can be a major undertaking. I spent years designing electronic circuits and troubleshooting EMI (electromagnetic interference) problems.
    deanosaurus and arkywally like this.
  11. Jun 12, 2016 at 11:17 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    I've found that LED lights are definitely RF dirty.
    I don't have interference with radio stations yet as far as I know, but if I dial the squelch down on the CB until it's just at the edge of static and then turn on any of my LED lights, I'll get static for sure.
    I don't think it's in the way they're wired, or the power or anything like that. I think the circuit boards in the lights themselves generate RF because of poor circuit design.
  12. Jun 12, 2016 at 3:18 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    That is where I was going but I sometimes get to technical
    The company may have a fix or not
  13. Sep 20, 2017 at 3:11 PM
    GulfCoastMike
    GulfCoastMike Co-pilot Angel
    Pascagoula, MS
    2017 MGM AC SR5 3.5L A/T
    Try this old fix.
    What you'll need is an electrolytic capacitor rated for at least 15 volts. These are directional, so be careful wiring them up.
    The value isn't especially important, but generally, the higher the better. One rated 2,000uF will work. Another rated, say 10,000uF would be excellent.
    Splice the positive lead as close as possible to the radio (or CB radio) and ground the negative lead. Capacitors only allow AC (noise, static) to pass. The noise will be passed to ground allowing a more pure DC to be fed to your device.
    It might be worthwhile to experiment doing the same thing to the power wires to the lights as well. These capacitors are really cheap.
  14. Jan 16, 2021 at 6:12 PM
    crobertsco
    crobertsco New Member
    Your LED lights are emitting RF radio frequencies. The LEDs are diodes which require an electronic circuit to light. This circuit it using the power wire as an RF radio antenna. The radio frequency being transmitting through the power wire is close to the radio frequencies in your audio radio station you are trying to receive. If your power wires are close to or are connected to your radio, then the LED RF is drowning out your radio. If your LEDs are Amazon imported lights then they do not have built in Ferrite Coils. However you can install them on your power wire (as close as possible) to your LED light. (one for each light). You can buy these on Amazon, they are cheap. While you are at it you should install a line filter on your radio power wire. RF signals can also be generated through the engine electronics. But most likely the Ferrite Coils (snap on beads) on your LED power wires next to the light will do the trick, since you did not have this problem before the LED light installation.
    Good luck, I'm a 40 year Ham Radio Operator with Search & Rescue.
  15. Jan 19, 2021 at 10:21 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Do you have any you recommend?
  16. Jan 19, 2021 at 10:42 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    you need to measure the frequency of the interference using an oscilloscope then calculate the capacitance needed to filter that noise frequency out.
  17. Jan 25, 2021 at 3:10 PM
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    I'd start with ferrite chokes on all the LED lights before you get into that. They are cheap like borscht and will probably solve it.
    6 gearT444E[QUOTED] and vicali like this.
  18. Jan 25, 2021 at 7:27 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    that may work as well. Could need a combination of both to completely eliminate. Wire routing can also help to lower the emissions. For example, twisting the wire pair together or using a shield wire.
