radio looses signal with hids on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JaimeDawg, Mar 28, 2012.
  1. Mar 28, 2012 at 11:43 AM
    JaimeDawg
    JaimeDawg [OP] make me a sammich
    Jaime
    Las Cruces, NM
    2011 trd off-road prerunner custom paint
    black saphire metalic paint with TRD off-road chameleon, 8000k hids on headlights and fogs, led map lights, led corner lights, saftey first baby seat mod in backseat, white/amber drls, devil horn emblems, trd seat covers, trd cai (old version)
    my radio looses signal whenever i turn on my hid headlights and when i turn on the fog hids it gets staticy.. is this due to a bad ground on hids? the fogs didnt come with a ground wire just plug and play..the headlights did and i put the ground next to the batteries ground on the fender well... do i need to get a bigger ground wire coming from the battery? or is this normal and just gotta deal with it cuz of the hids.:confused:
  2. Mar 28, 2012 at 11:47 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    When these plug n play HIDs first became popular i heard stories of cheaper ballasts causing radio interference. Not saying thats what this is. Id check all your wiring too.
  3. Mar 28, 2012 at 11:52 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Yeah, I have the same problem, but with only one set, my projectors don't do it, nor my fogs, but if I fire up my converted Hellas (55 watt) signal is full of static. But I don't much listen to the radio anyway, so it's not a big deal to me.
  4. Mar 28, 2012 at 1:22 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    common if you just bought the hids, where did you get them from?
  5. Mar 28, 2012 at 5:12 PM
    JaimeDawg
    Jaime
    Las Cruces, NM
    they were bought at a performance part store called RPM in el paso, texas
