Radio Not Working When Cold
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MotoMoose68, Oct 23, 2019.
  1. Oct 23, 2019 at 8:12 AM
    MotoMoose68
    MotoMoose68 [OP] Well-Known Member
    Ed
    Southwestern Colorado
    2014 Tacoma TRD Sport
    Strut Spacer and block lift, w/33" tires on custom wheels.
    I'm having an issue with my factory radio when it's below freezing. The radio seems to lock up in varying degrees and at times will do nothing. Not sure if it is tied to using a USB drive to play music or not. There are times the radio doesn't seem to recognize the drive (also when cold), but pulling it out and reinserting resolves this issue.
    Anyone else experiencing this, and if so, how did you resolve these issues?
  2. Oct 23, 2019 at 8:16 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  3. Oct 23, 2019 at 8:35 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    mine has a mind of its own
    sometimes turns on at random times and makes for a good conversation at a drive through while AxCx is blasting o_O
    an American grindcore band from Newton, Massachusetts.
    Cant post name of band. LOL
  4. Oct 23, 2019 at 8:55 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I don’t work well in the cold either.
    mine resets randomly a few times a month.
    MotoMoose68[OP] likes this.
  5. Oct 23, 2019 at 8:57 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    That’s funny because mine did the exact opposite. It would randomly turn off and stop working on hot summer days. The hotter the day the less it’d work until the AC cooled the cab off and then it’s be fine. I used it as an excuse to upgrade to a kenwood head unit.
    My guess was that the heating caused something to expand and make a connection not quite make contact. Totally a guess though.
    MotoMoose68[OP] and whatstcp like this.
  6. Oct 27, 2019 at 12:38 PM
    jedirye
    jedirye Wannabe
    Florida
    2013 Baja Supercharged
    Mine had issue with screen colors being inverted. I started a post (with pic) but no one else really had the problem...
    Long story short, replaced it under warranty but it was a bear. They sent a Toyota tech out to "verify" with dealership it really needed replacing, and gave a rental car in the process. A rental car for a radio problem. So basically, that radio or the labor associated (or both) might be expensive...
  7. Oct 27, 2019 at 3:52 PM
    Wrench1225
    Wrench1225 Well-Known Member
    jim
    NY
    SR5 4x4 db cab sb
    Rock sliders,total skids,toytec3" lift w adjustable UCA's and O ME,leaf spring pack, w toytec 2.5 rear shocks,diff.drop andBF Goodrich A/T 275 70 R16 (spare fits nicely under bed) Ultra machined Wheels, front camera. Seat covers,Bed liner spray(can't put a scratch in it) currently pricing diff.lockers with heavy duty pumpkin gears. Lastly winch w low profile bumper
    BS the radio is a 30 min job. The radio clips in and the plug ins are like playing circles and squares. Virtually impossible to get them wrong. Sounds like the Tech was pulling a fast one on his boss. Billing him 2hrs for a 30 min adventure. That’s why their nickname Steeler ships
  8. Oct 27, 2019 at 6:58 PM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Hi everyone. Anyone ever turn a 2nd gen. Base 4x4 with a stock rear diff into a stock diff w lockers. I believe the stock rear diff w/o lockers is a 8 and the stock diff w lockers is a 8.4 If I’m understanding this correctly the difference between the two is that the diff w lockers has ticker gears but the gearing ratio is the same as the stock diff w/o the lockers. Is this correct? My question is why bother with the 8.4 I would install a locker in the 8 and call it a day.Has anybody done this?
  9. Oct 27, 2019 at 7:59 PM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    PC boards and electrical solder expand and shrink according to changes in temperature in different amounts. Extreme temperatures on either end of the normal temperature spectrum will crack solder joints over time. If the problem is found early enough just reheating the solder with an iron will fix the problem. If the problem is ignored for a long period of time the solder will need to be removed, the contact points cleaned of corrosion, and resoldered. The most difficult aspect of the job is finding which solder joints are cracked. Cracks can usually be seen with a quality magnifying glass but not always.
    Switche contact points within the switches are also adversely affected by extreme changes in temperature. Rotary switches are by far the worse culprits but push button switches can also be affected. Electronic parts cleaner spray will usually repair most switches. Give the cleaner time to evaporate prior to using the equipment.
    High humidity areas can also adversely affect electronics by causing corrosion.
    Most modern power window/lock switches have their electrical connections within the switch held together by rivets. Corrosion can occur in these connections fairly easily.
    Lastly not all solder is created equal. GM products from the 1970's to present day use notoriously poor solder. With the increase in costs of solder, pencil pushers making decisions within corporations, most newer electronics use solder of a lesser quality than in the past.
    Wrench1225 likes this.
  10. Oct 28, 2019 at 9:12 AM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Great post right to the point,Lam.
    LAMCKMA007 likes this.
