Radio Quit working
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mjw2002, Jan 1, 2016.
  1. Feb 3, 2022 at 6:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yes sir, follow the fuckery here - https://www.tacomaworld.com/threads/kwiks-80-series-land-cruiser-bs-thread.752018/
    I plan to redo almost all the wiring, but being my daily now I need to plan it right. I've got leather replacements on the way for the 2nd row seating. 3rd row seating will sit in storage while I figure out what I'll do for the fronts.
    When seats come up and out, it'll be the best time to add sound dampening and run new wiring.
  2. May 5, 2022 at 2:15 PM
    Montego Murph
    Montego Murph Member
    Murph
    Central IL
    2003 4Runner V8 LTD / 2002 Tacoma V6 TRD
    Would you be willing to share either the source for the schematic, or a photo of the resistor location? I've been doing my own searching for a while and can't find either. Plenty of wiring diagrams for installation are out there, but none for repair.
    Jimmyrace likes this.
  3. Feb 26, 2023 at 7:55 AM
    Jimmyrace
    Jimmyrace Well-Known Member
    JR
    Louisville, KY
    Betty '03 Taco MTM Xtra-cab DLX 5VZFE
    OME struts / springs / leaf pkg :: SPC upper A ::
    Yeah mine decided to quit working after a good freeze late dec. '22 ... Glad i found this thread to perhaps help the troubleshooting - if i find tyhe schem's i will post. i yanked mine not long after it happened & checked my constant & ignition power to ground and all s well in those respects, so yeah this has been a bit confusing as i had never had an issue either (& i happen to love my stock radio esp b/c of the tape player, but i also just like keeping some things stock) ... also i need to get this thing powered so i can retrieve my music from it's icy grasp lol. Probs gonna go disconnect the battery here in a few & see if that anything. Also i did a general web search & came up w/ a forum that was discussing sometimes they 'lock' & a code is needed to 'unlock' & has to be done in a certain way & a certain number of times ... but i also do not know whether their stereo units were 'bricked' or if they were showing power but not working ... will do more research on that & try to have an answer.
    Bivouac likes this.
  4. Feb 26, 2023 at 10:32 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Mine was working but the CD died. I'm a stock guy, not an auto audiophile, picked one up off fleabay, pristine, $125. I know it will die again someday but see attachment. The old one lives on a 12v PS in the garage for the radio only.
    Jimmyrace, Squirt and Bivouac like this.
  5. Feb 26, 2023 at 11:12 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I had a few of the stock radios just die as everything is all on the board without the board schematic nothing I can do.
    In most cases you can pick up the stock radios pretty cheap I got a few for shipping costs when users up grade to aftermarket.
    I was going to take them to The local radio repair tech but since I have them replaced I just never did.
    Jimmyrace[QUOTED] likes this.
  6. Feb 27, 2023 at 6:37 AM
    Jimmyrace
    JR
    Louisville, KY
    Update: I disconnected the battery for a good while yesterday afternoon while i cleaned the battery & terms off from some acid & corrosion while i was bs'ng w/ a friend so probs about an hour, when i hooked it back up it didnt even spit out the cd & tape - like it has No power whatsoever, so i can only guess fried board or some such thing. I went back thru my searches & found the site where i came across the 'locked' issue, & it seems everyone who had that problem theirs had power & was giving them some sort of an error code ... so yeah mine is a brick at present. i didnt end up pulling it out again b/c it was time to have a few beers & play some horseshoes w/ a buddy i dont get to visit w/ very often. Got work to do & rain coming in so it will be a few days before i get around to pulling the unit again. bah.
    2ndtaco4me likes this.
  7. Feb 27, 2023 at 6:42 AM
    Jimmyrace
    JR
    Louisville, KY
    SO You're the one who got that one for cheap off the fleabay - damnit you beat to it, Yeah that was good deal ... i was totally eyeballing it but didnt pull the trigger b/c was still hoping (beyond hope) i could fix this thing.
    btw - love that attachment Lolol Thanks for laugh this morning
    rocknbil[QUOTED] likes this.
  8. Feb 27, 2023 at 6:44 AM
    Jimmyrace
    JR
    Louisville, KY
    would actually like to see the set-up of the old one in the garage that sounds fun
  9. Feb 27, 2023 at 6:46 AM
    Jimmyrace
    JR
    Louisville, KY
    I'll probs cruise over the local yard & see if i come across any - there's 2 4runners that were brought in just a few months ago - i think they sell the units for like $35- or something
  10. Feb 27, 2023 at 6:51 AM
    Bivouac
    I have been doing that for years 12VDC power supply assorted different factory radios and speakers over 40 plus years.
    Then one also needs an antenna.
  11. Feb 27, 2023 at 3:01 PM
    rocknbil
    Bill
    Well, I think I overpaid for it, don't think it was the same one. I wanted one that would get a little CD time out of it, it was clean and works well, for now. It'll die eventually.
  12. Feb 28, 2023 at 4:59 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Probably well known, bad fuses can’t be verified by just looking for signs of a burnt or broken element. One of mine was bad and showed absolutely no signs of being so. Coincidentally, it was the radio/cig and clock fuse at driver door fuse panel.
  13. Mar 1, 2023 at 8:53 AM
    Jimmyrace
    JR
    Louisville, KY
    Thanks - yeah i checked them - clock is working & i can use the outlets for charging phone etc
  14. Mar 1, 2023 at 12:35 PM
    Caslon
    Probably been suggested, but getting the unit somehow hooked up externally would tell you. You might have to bring it into an car audio shop and get charged some. Years ago I found a radio with CD player on Ebay. Gotta make very sure it matches the numbers on the back of your existing unit if it turns out yours is bad. Also, I believe radio/cd units have their own separate inline fuse as a safety feature. Also, fuses that control the radio most often control other dash components. If no other dash components are affected, it’s almost for sure your radio is bad.
  15. Mar 8, 2023 at 9:31 AM
    #35
    Jimmyrace
    JR
    Louisville, KY
    Thanks. yeah i do need to yank it out again & tear into it a bit - i was thinking (hoping) there is perhaps a small fuse on the board, but others have noted perhaps it is a bad resistor ...
    #35
