Radio sound issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sweaver22, Feb 11, 2024.
  1. Feb 11, 2024 at 6:13 AM
    Sweaver22
    Sweaver22 [OP] Member
    Stephen
    23 Toyota Taco
    So I bought 23 taco sr basic rear door speakers are not putting out any sound? Suggestions? There is barely any sound at all when fade to back very weak? Is it Toyota or wiring?
  2. Feb 11, 2024 at 6:25 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes I’ve noticed rear speakers nowadays get little power. Basically new vehicles standard operating procedure, it may vary vehicle to vehicle, brand to brand. YMMV. It’s an opportunity to upgrade the HU and speakers.
  3. Feb 11, 2024 at 6:34 AM
    Taco22trdor
    Taco22trdor Well-Known Member
    East Tennessee
    2022 Tacoma TRD Off Road White
    Toyota uses super cheap made speakers and the rear doors are the worst. I could buy better speakers for $20 at Wally world in the 80's than what came stock in my 22 Tacoma. There are several threads on speaker upgrades here. I replaced my door speakers with Kicker speakers for not too much money. Welcome to Tacoma World.
  4. Feb 11, 2024 at 6:57 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    a bit over-dramatic there.
    considering i've been collecting speakers for well over 25 years, $20 walmart speakers still sucked, and they were much worse-built than the oem speakers. they were really just heavier due to the difference in magnet technology used. oem is a self-shielding neodymium design which has an extremely high magnetic-flux-per-ounce ratio, where you're comparing it to the older ferrite magnet iterations that needed to be oversized because of their extremely low flux-per-POUND ratio. the build quality of the oem speakers is on par with $50-100 budget speakers nowadays, the composite frame is actually leap years ahead of many budget speakers.
    overall, i had more issues with the factory eq than i ever had with the speakers.
  5. Feb 11, 2024 at 7:02 AM
    Taco22trdor
    East Tennessee
    lol. calm down. the stock speakers are still trash.
  6. Feb 11, 2024 at 8:29 AM
    Sweaver22
    Stephen
    23 Toyota Taco
    I already upgraded speakers to Kickers but the sound is still terrible. The front speakers sound better but back still nothing is it the wiring to the back speakers?
  7. Feb 11, 2024 at 8:39 AM
    soundman98
    NW Indiana
    it's the radio.
    MKC1911 likes this.
  8. Feb 11, 2024 at 8:40 AM
    soundman98
    NW Indiana
    not really. just your perception. i've dealt with far worse than what's included with the tacoma.
  9. Feb 11, 2024 at 8:41 AM
    rnish
    Tacoma 2nd gen
    Assuming you are running the OEM HU. My guess is the new rear speakers are not efficient enough for the limited power going to the rear.
    Chew likes this.
  10. Feb 11, 2024 at 9:05 AM
    Sweaver22
    Stephen
    23 Toyota Taco
    So should I run newer wiring for the back door speakers?
  11. Feb 11, 2024 at 9:05 AM
    Sweaver22
    Stephen
    23 Toyota Taco
    Everything is factory just upgraded the doors speakers to kickers
  12. Feb 11, 2024 at 9:29 AM
    soundman98
    NW Indiana
    you need a better radio.
    Chew likes this.
  13. Feb 11, 2024 at 10:17 AM
    kergilman
    kergilman Active Member
    Kevin
    Tualatin, Oregon
    2009 2TRFE Tacoma SR5 Access Cab
    2" lift, ebay rock crawlers, ebay carpet bedliner
    Might want to replace the factory speaker wiring with a larger gauge. Removing the door paneling and installing dyno-mat on door will make the difference.
  14. Feb 11, 2024 at 10:21 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    not putting out "any sound" or "very weak"?
    There's a difference.
    no sound- something wrong
    very little- as designed, and as mentioned, you will need a different HU
  15. Feb 11, 2024 at 10:26 AM
    Sweaver22
    Stephen
    23 Toyota Taco
    Very weak
  16. Feb 11, 2024 at 10:27 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    very normal, that is the way the HU was designed, so you will need a new one if you wish to pump more sound to your rear passengers.
