Radio sounds like crap on AUX
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jetman1979, Apr 11, 2013.
  1. Apr 11, 2013 at 1:41 PM
    Jetman1979
    Jetman1979 [OP] Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    My stock radio sounds like crap in my 09 when I plug in my I Phone. Radio and CD sounds normal. I want to use my music on my Phone for my trip to California there are lots of spots with no stations. I am bumming.
  2. Apr 11, 2013 at 1:44 PM
    Skinny Rogers
    Skinny Rogers U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    Mine is the same way. Crap on aux and a lot quieter when using sat radio. Have to turn it all the way up when using iPod/iPhone and still too soft. I'm just gonna replace my stock radio unless I hear a better option.....
  3. Apr 11, 2013 at 1:54 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I think the Tacoma stock radios just arent the best quality. :eek:
  4. Apr 11, 2013 at 1:57 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Have u checked your cable? Try a diff one
  5. Apr 11, 2013 at 2:12 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Make sure the volume on the iPod is all the way up. Control the volume by the radio volumn knob.
  6. Apr 11, 2013 at 2:28 PM
    Jetman1979
    Michael
    North Texas
    2009 tacoma 4X4
    Well I made it alot better on my settings there is a sound check. I turned it off and it is alot better still have to turn the truck radio to max but at least I have bass now.
  7. Apr 11, 2013 at 2:33 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    Hmmmm sounds odd to me. I have an iPhone 5 and will use AUX cable sometimes (mainly I use Bluetooth audio) The sound quality sounds the same as listening with headphones. I also do not have to turn the volume up to max. It is a bit quieter but probably only by 3-5 levels.
  8. Apr 11, 2013 at 4:20 PM
    Jetman1979
    Michael
    North Texas
    2009 tacoma 4X4
    Yep IPhone 5 same one I have if you go to setting on it go to the music tap to open you will see a sound check that must be off to use the aux input or it. Sounds like a 60s transistor radio.I dont have bluetooth on the truck my 2010 tundra did. made a bo bo I have the 4g phone.
  9. Apr 11, 2013 at 4:34 PM
    Seer
    Seer Well-Known Member
    Tom
    Bayfield, CO
    13 Double Cab 4x4 stock
    Mine sounds like crap through Blue Tooth, but is great with the Lightning cable and aux.
  10. Apr 14, 2013 at 10:30 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    as far as the volume goes, you may want to check your iPhone/Pod to make sure the volume limiter is not turned on. also, it helps if you have the output volume on high for the device your plugging in, if it isn't already. but yeah, i agree, the sound isn't the same as the radio.
  11. Apr 14, 2013 at 10:32 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get a USA Spec , I love mine
  12. Apr 14, 2013 at 10:33 PM
    iliketurtles
    iliketurtles Well-Known Member
    I have a 2011 and the volume is really low when I use my aux input too. I've tried several different phones and cables with the same result.
  13. Apr 14, 2013 at 10:33 PM
    OZ-T
    Peter North
    British Columbia
  14. Apr 14, 2013 at 10:44 PM
    lpfm1990
    lpfm1990 Well-Known Member
    Brian
    Newfane NY
    13 tundra dbl cab rock warrior
    trd duals
    from personal exprience at work using my iphone to play music threw my radio since i have zero radio recepition working in a big tin can building, turn your iphone/ipod or what ever to the max volume with the volume limit off, using the side volume control, click it down once or twice, that takes care of the distroation, otherwise, does it sound like crap, and also, buy a better grade cord, the cheap $5-$10 ones, suck, they are just, cheap!
  15. Apr 14, 2013 at 10:56 PM
    fireroad
    fireroad Well-Known Member
    McCall, ID
    In addition to "sound check" and "volume limit" off, had you tried different settings in the "EQ"? I just leave mine off but there are and number of settings listed and some may sound better than others through the aux. Also try a different cable, radio shack has some pretty good quality ones without paying for the name like Monster.
  16. Apr 15, 2013 at 8:32 AM
    scotch
    scotch Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma, 2015 Tacoma, 2005 4runner 4.7L
    Lots of Stuff
