Radio Static When my headlights are on?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 20somethingwidataco, Apr 26, 2018.
  1. Apr 26, 2018 at 1:14 PM
    20somethingwidataco
    20somethingwidataco [OP] Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    So I've done some research, Found out that some LED headlights cause static through your stereo when they are turned on. I've had my led headlights/fog lights/day time running lights with my current set up (kenwood head unit, alpine amp, jbl club door speakers) for about 2 months now. And all of a sudden today on the way home, (I have an '08, but I turn the running lights, or parking lights on all the time) I started receiving static through my stereo. Whats even weirder is when I gave it gas, the static mimicked the throttle input. Any idea's?
    I swear this all started when I rerouted my rca cables under the seat carpet......
    BillsSR5 likes this.
  2. Apr 26, 2018 at 1:18 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    remove LED headlights, see if it goes away
  3. Apr 26, 2018 at 1:18 PM
    20somethingwidataco
    Will
    Washington State
    I'll try it. But it still doesn't make sense to me why It would all of a sudden start happening.
  4. Apr 26, 2018 at 1:19 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    could be a manufacturing defect of some kind... maybe some sort of shielding failed? who knows.. I would start there though as they're easy enough to pop in/out. Heck, if it stops, put one bulb in at a time, swap them, see what makes the noise come back. Might just be one bulb.
  5. Apr 26, 2018 at 1:20 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    what happens if you reroute the cables back?
    maybe you have one that's loose
    TacoJova likes this.
  6. Apr 26, 2018 at 1:25 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    This same thing happened to me in my old Saab and an alpine amp/ headunit (at least the static and weird whine tied into the throttle- I never had led headlights). It also just started happening one day (wasn’t happening and then all of a sudden boom static) I tried things like in- line noise reducers, rerouting the cables and shielding cables. Nothing worked. Ended up running a power line for the headunit directly from the battery- that solved it. Hope this helps.
  7. Apr 26, 2018 at 1:31 PM
    20somethingwidataco
    Will
    Washington State
    I'm going to try that this weekend. Stressful as hell as I already have no time
  8. Apr 26, 2018 at 1:32 PM
    20somethingwidataco
    Will
    Washington State
    I'l try that. I have good back up bulbs if that's the case
  9. Apr 26, 2018 at 1:35 PM
    JoeK
    JoeK Well-Known Member
    NC
    15 MGM TRD Sport DCLB
  10. Apr 26, 2018 at 1:39 PM
    Spiffy09
    Spiffy09 Well-Known Member
    '10 White TRD O/R DCSB
    Could be a weak ground somewhere in the audio system, typically when static is picked up and RPM related there's interference coming from the ignition coils.
  11. Apr 26, 2018 at 1:41 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    It's probably a loose ground
  12. Apr 26, 2018 at 1:43 PM
    knottyrope
    Knotty
    Bahstun
    he didn't mention if he was off roading or not, cant believe dirt will do that ;)
    TacoJova[QUOTED] likes this.
  13. Apr 26, 2018 at 2:17 PM
    20somethingwidataco
    Will
    Washington State
    Well it was my running lights. One of them was flickering so I took it out and boom no static, but when I took out the bad on, the good one stopped working. Now I can't get either of them to work. What fuse did I blow? I tried using the leds again, nothing, put the stock bulbs back and again nothing.
  14. Apr 26, 2018 at 2:24 PM
    20somethingwidataco
    Will
    Washington State
    Sorry, is the side bulb, what ever the second bulb besides the headlight is in the headlight assembly
  15. Apr 26, 2018 at 2:27 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    its definitely the LEDs,i put in a high priced PIAA LED Fog lights and had the same issue with weaker FM stations,
  16. Apr 26, 2018 at 3:24 PM
    20somethingwidataco
    Will
    Washington State
    Read post 13 and 14
  17. Apr 26, 2018 at 3:59 PM
    20somethingwidataco
    Will
    Washington State
    Nope, besides the occasional gravel road I can't afford to break parts and offroad her
  18. Apr 26, 2018 at 4:01 PM
    20somethingwidataco
    Will
    Washington State
    Would I have blown a fuse pulling out a bulb while the running lights were on? The right side was flickering so while the lights were on I took out the bad bulb and the other side stopped working. I checked all 10 amp fuses labeled "head" and they were all fine. Hopefully I didn't mess up my side lights
  19. Apr 26, 2018 at 4:59 PM
    Muddinfun
    Muddinfun Well-Known Member
  20. Apr 26, 2018 at 5:21 PM
    20somethingwidataco
    Will
    Washington State
