Radio stays on when truck is turned off/ key removed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by harleyxl181, Oct 29, 2011.
  1. Oct 29, 2011 at 6:50 AM
    harleyxl181
    harleyxl181 [OP] Member
    ny
    08 tacoma sr5
    hello all, I have an 08 v6 double cab tacoma. Completely stock audio setup and electronics, automatic windows. Just a few days ago I turned my truck off and the radio and clock stayed on. I learned the radio stays on for about 30 seconds after the truck is turned off and then will shut down. My automatic windows will also operate for about 30 seconds once I shut the truck off and the key is removed. I do not know how long it takes for the clock to shut off. My battery has not drained enough to not start the truck yet, but I need to get this problem fixed asap. The truck has 50,000 miles so it is beyond warranty. Does anyone know of this problem or have any suggestions where I should investigate? Thanks for the help. Oh yeah, this all happens when the key is removed and the door has been opened and closed
  2. Oct 29, 2011 at 6:52 AM
    Brunes
    Brunes abides.
    Rotorhead
    Mine does that all the time. It all shuts off when I open the door. It's built to do that so you have power to get the windows closed and what not.
  3. Oct 29, 2011 at 6:52 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Normal, if you open the door it will go off.
  4. Oct 29, 2011 at 6:53 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    That is a standard thing. My truck does it too. I have an 07. Kinda cool if you stop somewhere and shut the truck off. Can still operate the windows and what not. It won't have a bad effect on your battery. Promise.
  5. Oct 29, 2011 at 8:52 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Does the clock even shut off? I can't remember if it does.
  6. Oct 29, 2011 at 9:02 AM
    harleyxl181
    ny
    08 tacoma sr5
    Yes everything should shut off once the door is opened.
  7. Oct 29, 2011 at 9:02 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    x2
  8. Oct 29, 2011 at 9:23 AM
    harleyxl181
    ny
    08 tacoma sr5
    I understand that, my problem is the radio and windows will work for about 30 seconds after the door is opened.
  9. Oct 29, 2011 at 9:26 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    But it does go off by itself, or do you have to do something to make them go off?
  10. Oct 29, 2011 at 9:34 AM
    Brunes
    Brunes abides.
    Rotorhead
    That would lead me to believe there is a problem with the door switch that discharges the stored power...but it does go out after 30 seconds or so?? That means the power isn't coming form the battery continuously.
  11. Oct 29, 2011 at 9:57 AM
    harleyxl181
    ny
    08 tacoma sr5
    Yes the radio will turn off after about 30 seconds. I am not sure how long it takes for the clock to turn off. They both do turn off eventually though.
  12. Oct 29, 2011 at 10:15 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Sticky relay maybe? Not sure what's in the circuit to provide that extra time after the key is off. If it's just a plug in relay, should be easy to change and see if that takes care of it. And probably cheaper than a dealer diagnostic charge. Search for factory service manual on here. There should be a link somewhere. Otherwise, I have used the one on TTORA.
    I know mine goes off when the door is opened.
  13. Oct 29, 2011 at 10:15 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    It does sound like the door switch is not working. Does the dome light come on when you open the door?
