Radio suddenly not recognizing USA Spec PA15
Discussion in 'Audio & Video' started by OZ-T, Jan 3, 2015.
  1. Jan 4, 2015 at 5:25 PM
    #41
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    I put it in the glove box the first time , second time I pulled the shifter trim and the console and ran it so the ipod could be accessible in the console
  2. Jan 4, 2015 at 6:03 PM
    #42
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Like I said......15 mins. :cool:
  3. Jan 4, 2015 at 6:08 PM
    #43
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    USA spec technical support is very helpful. But sometimes these interfaces just need to have a hard reset. Unplug it at the box for 1 min then plug it back in. That usually works with these unless there's something actually wrong with it. Whenever I've installed these in vehicles I always made a point to put the box somewhere serviceable with these kind of problems in mind.
  4. Jan 4, 2015 at 9:12 PM
    #44
    OZ-T
    Peter North
    British Columbia
    Your name is 4x4 , but you had a Prerunner and now you drive a Jeep , I think we're done here
  5. Jan 5, 2015 at 5:56 AM
    #45
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :jellydance:
  6. Jan 5, 2015 at 11:04 AM
    #46
    OZ-T
    Peter North
    British Columbia
    K , so anyway , I popped out the front cupholder trim piece to get at the location where I mounted the USA Spec box
    Pulled out the box itself and found the DIP switches were all where they should be but just because I already had it out I cycled them on and off to make sure they were positively seated where they should be ,not sure if that was any help but whatever
    Left the unit unconnected for about 5 minutes , reconnected the cables and now everything works fine again so not sure if it was the DIP switches or just no power that reset the unit but it has resolved itself
  7. Jan 5, 2015 at 12:25 PM
    #47
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Nice you got it working! So proud of you!
  8. Jan 5, 2015 at 12:35 PM
    #48
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    So, after all that, the issue turned out to be a loose screw between the gas pedal and the steering wheel :blahblah:
  9. Jan 5, 2015 at 1:28 PM
    #49
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And it only took 2 days.
  10. Jan 5, 2015 at 2:01 PM
    #50
    OZ-T
    Peter North
    British Columbia
    FU GUYZ , I was sitting in my pajamas all day yesterday
  11. Jan 5, 2015 at 2:02 PM
    #51
    OZ-T
    Peter North
    British Columbia
    Box needed to be reset
  12. Jan 5, 2015 at 2:04 PM
    #52
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your point?
  13. Jan 5, 2015 at 2:05 PM
    #53
    OZ-T
    Peter North
    British Columbia
    I was sitting in my pajamas inside not in my truck herpaderp
  14. Jan 5, 2015 at 2:08 PM
    #54
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And it still took you 2 days.
  15. Jan 5, 2015 at 2:14 PM
    #55
    OZ-T
    Peter North
    British Columbia
    Wasn't that big of a deal to me , glad it's fixed now though
    Thanks to everyone that posted
