Radio/TPMS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Masterdro, May 1, 2025 at 8:55 AM.
  1. May 1, 2025 at 8:55 AM
    Masterdro
    Masterdro [OP] New Member
    Andres
    Ooofas
    Awesome
    If anyone can help that would be awesome. I have a 2019 Taco sr5, the radio doesn't want to turn on and the TPMS light is still on. But all my tires are filled up, there is no puncture or anyting of the sort on the tires.
    Does anyone have an ideas? Suggestions would be appreciated.
  2. May 1, 2025 at 9:21 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I would get the TPMS scanned by a Autel TS501 or similar by any tire shop...verify you actually have sensors installed in the wheels. As for the radio, you will either have to do some troubleshooting or take it in. Start with a fuse and check connections on the back of the radio. Easy to do in less than 10 minutes with a 10mm.
  3. May 1, 2025 at 9:33 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Welcome to TW.
    Not sure what's up with your radio. Is this a new problem?
    Is the TPMS light on solid or is it flashing?
    Flashing usually happens with a rapid loss of pressure.
    Solid on light often signals the end of life for one or more sensors - time to replace (usually the battery in them dies).
  4. May 1, 2025 at 9:39 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Try the TPMS reset located under the steering column.
    Read your owners manual or google for directions on proper reset.
    airforceb2cc likes this.
  5. May 1, 2025 at 9:42 AM
    airforceb2cc
    Don
    KCMO
    Good suggestion! I always forget about that stupid button.
  6. May 1, 2025 at 11:36 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    One bad sensor means none of them will work. As others have stated, get them checked.
  7. May 1, 2025 at 8:25 PM
    Masterdro
    Andres
    Ooofas
    Awesome
    Thank you all for the suggestions. I will let you guys know what I find.
    xBloodxLinex likes this.
  8. May 1, 2025 at 8:34 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Yep, if you have a sensor that lost connection/died, the TPMS light will flash for a bit then stay solid. I have one that only does this on long freeway road trips :mad:
