Radio turns off and truck wouldnt crank
Discussion in '1st Gen. Tacomas (1995-2004)' started by JimBeam, Aug 11, 2013.
  1. Aug 11, 2013 at 5:52 PM
    JimBeam
    JimBeam [OP] BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    So no warning signs or any hard cranking or anything like that
    I was driving down the interstate today (approx 25 mi trip) and about halfway thru, the radio turned itself off and would not turn back on. I also noticed the clock seemed very dim on the right side. I arrived at my apartment, parked the truck and turned it off. I immediately turned it back on (but no crank) and the radio worked again so i turned it off and went inside. Came back out a couple hours later to go to dinner and the truck didnt want to crank and never did, but eventually made the tell-tell rapid click of a dead battery. no big deal right? wrong. I went BACK out a couple more hours later and the truck cranked right up long enough for me to back it into my spot so I can work on it if need be.
    Is my alternator shot? any other ideas? No other issues that i've noticed or see/hear
  2. Aug 11, 2013 at 5:57 PM
    Large
    Large Red
    Alternator, maybe a fuse I would think.
  3. Aug 11, 2013 at 5:58 PM
    JimBeam
    JB
    2015 Tundra
    i guess i shouldve probably added in the obligatory info
    2002 V6 with 139700 miles, stock radio
    Battery is from July 2010 and Alternator is from sometime in 2009
  4. Aug 11, 2013 at 6:01 PM
    sander1036
    sander1036 Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    As odd as this may sound clean your battery terminals, I thought I had a starter going out once but it was actually my terminals were dirty and corroded
  5. Aug 11, 2013 at 6:02 PM
    JimBeam
    JB
    2015 Tundra
    that was actually the only thing i really checked :laugh:
    terminals are good and connections are tight
  6. Aug 11, 2013 at 6:08 PM
    sander1036
    :laughing: hmm well, did your truck seem to run odd at all when the radio was off and the clock was dim
  7. Aug 11, 2013 at 6:10 PM
    JimBeam
    JB
    2015 Tundra
    nope...no weird noises or anything odd...accelerated and idled fine
  8. Aug 11, 2013 at 6:12 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Just saw this.....gimme a call.
  9. Aug 11, 2013 at 6:16 PM
    sander1036
    I would think if it was the alternator it would affect the way the motor was running along with the radio and clock not working properly, but maybe it's just on the fritz
  10. Aug 11, 2013 at 6:17 PM
    JimBeam
    JB
    2015 Tundra
    agreed
    will and jamie and a few others can attest that the last time i had an alternator go out...i went about a mile or so before the truck just quit running
  11. Aug 11, 2013 at 6:26 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    When I had my alternator die in another car, it did the exact same thing as you are experiencing. It started back and completely drained my battery two days later.
    Is your 2009 alternator a Toyota brand?
  12. Aug 11, 2013 at 6:28 PM
    JimBeam
    JB
    2015 Tundra
    unfortunately no
    I had to scramble and buy an autozone one or something back in 09 because we were out on the trail when it went out and autozone was the only place within 100 miles that was open and had one in stock...
  13. Aug 11, 2013 at 6:29 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    My bet is on the alternator then.
  14. Aug 11, 2013 at 6:30 PM
    sander1036
    Yeah I'm stumped hopefully someone will chime in... But maybe it wouldn't hurt to test the alternator just in case
  15. Aug 11, 2013 at 6:33 PM
    JimBeam
    JB
    2015 Tundra
    gonna test battery and alternator tomorrow and see whats what
  16. Aug 11, 2013 at 6:33 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    Mine did this a year ago radio went nuts, the shut off then my truck turned off while going like 35mph it was weird. changed the alternator and no more problems.
  17. Aug 12, 2013 at 8:21 PM
    JimBeam
    JB
    2015 Tundra
    luckily my truck allowed me to get home with no issue
    it will not start now whatsoever
    a buddy of mine is a mechanic and will be picking it up later this week because I dont have the time or motivation to try and change the alternator by myself
  18. Aug 12, 2013 at 9:46 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    get a voltmeter and check the voltage on the battery. it should read 12-12.5 if it's fully charged. while running, it should be close to 14V. or take your battery and/or alternator to you local parts store to get it tested.
    check both reading and the results will tell you which parts is bad.
  19. Aug 13, 2013 at 7:40 AM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    I'd guess alternator too.
    TLDR version: I was cruising down the freeway in my Corolla one Christmas Eve on my way to my parents' house when the check engine light came on. Being far from home and not being mechanically inclined, I continued on. After a while my headlights slowly dimmed until they went out and I was driving in near darkness. I decided the prudent thing to do was to take the next exit. I found a gas station with a payphone (long before mass market cell phones), parked my car and called my dad. I tried to start the car and it was a dead Jose'. Luckily McD's was still open so I waited there for an hour for my dad to arrive. The following Monday morning we hit Schucks and picked up a new alternator. Luckily it was a 10 minute swap as it was on top of the engine in my Corolla. Jumped it and it fired right up. Let it idle for 20 minutes, turned it off, and there was enough charge again to start under it's own power.
    So, yeah. Alternator in my experience.
  20. Aug 13, 2013 at 9:13 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check your grounds. They are notorious for causing weird problems like that. Check the voltage drop on your battery cables as well. A high drop indicates a bad cable/connection.
