Radio turns on with left turn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Secondchildhood, Feb 27, 2012.
  1. Feb 27, 2012 at 2:07 AM
    Secondchildhood
    Secondchildhood [OP] Active Member
    2018 Tacoma
    This just started.
    If I make a sharp left, at times, my radio comes on.
    The truck is a 2010. I have touched, changed nothing. Any ideas?
  2. Feb 27, 2012 at 2:29 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Maybe hitting the steering wheel audio controls accidentely ?
  3. Feb 27, 2012 at 2:37 AM
    Joe D
    Joe D .
    Still under warranty?
  4. Feb 27, 2012 at 2:59 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    dont turn left anymore, just make all rights
  5. Feb 27, 2012 at 3:36 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    The radio turns on when you turn left. Well, like Ron said, don't turn left unless you want the radio on. :D
    Seriously, that's a really odd problem. Is the behavior limited to just when the vehicle is moving? If so (and assuming you're not accidently hitting the audio controls on the steering wheel), try wiggling the radio and wiring under the dash to see if any of that will trigger it. Also check to see if the fuse for the radio is fully and firmly plugged into it's socket. You may also want to replace the fuse in case it's partially defective.
    If it happens all the time, even when the vehicle is not moving, you may have a problem with the wiring or switches inside the steering wheel.
    In the end, if you don't have the electrical skills to find and fix the problem yourself, you'll probably have to take it to a qualified repair shop.
  6. Feb 27, 2012 at 4:07 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    This^^
    but really take it to the dealership, you've got a short somewhere.
  7. Feb 27, 2012 at 4:30 AM
    Secondchildhood
    2018 Tacoma
    I just went out and started the truck and hit all the buttons on the steering wheel. When I hit "Mode" the radio turned on. I never knew I could turn the radio on from the steering wheel. I assume I am hitting "mode" when I make a sharp left. Thanks for the help. Sorry for the confusion.
  8. Feb 27, 2012 at 4:53 AM
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    That's exactly how I found out the mode button turns the radio on :D
  9. Feb 27, 2012 at 5:33 AM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    which hand are you driving/turning with? glad you figured it out before going to the dealer.
  10. Feb 27, 2012 at 5:43 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Beat me to it. I found that out a few days ago.
  11. Feb 27, 2012 at 8:15 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Perhaps it was owned by an old NASCAR driver who liked his music .... :cool:
