Radio Wiring Harness layout 2000 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000GTacoma, Nov 27, 2011.
  1. Nov 27, 2011 at 7:13 PM
    2000GTacoma
    2000GTacoma [OP] Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I have a 2000 tacoma ext ca v6 4x4 manual sr5. It has an aftermarket radio installed that was installed by a shop a couple years ago but my dimmer switch has never dimmed the radio. I don't think the dimmer wire was ever hooked up. Does anyone have a manual or something that tells what the different color wires are? I know what wire off the radio to hook into I just need to know which one on the truck. Thanks
  2. Nov 27, 2011 at 7:23 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Aftermarket stereos don't normally respond to the dimmer switch. Instead, they have only two brightness settings. The first (brighter) one is when the stereo is on, but your lights are not. The second (slightly dimmer) on is when the stereo AND your light are on. (This was the case on the Alpine I ran in my '92 Toyota Pickup and is also the case with the Kenwood Excelon KDC-X895 I recently installed in my Tacoma.)
    That said, if I still have the wiring diagrams, I'll post them here shortly...
  3. Nov 27, 2011 at 7:31 PM
    2000GTacoma
    Snow Hill NC
    mine has a dimmer setting. i can turn it on or off. when on it doesnt do anything at all. the factory radio dimmed and my current radio is a pioneer fh-p8000bt. according to the diagram on pioneers website the radio dimmer wire is orange white heres the link http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/FH-P8000BT_InstallationManual0228.pdf
  4. Nov 27, 2011 at 7:41 PM
    Norton
    That's called the illumination lead on mine, and it does what I said above. I've never had a Pioneer stereo, so I can't confirm or deny what you're saying. I suspect, however, you're not seeing any dimmer response because it's setup like both of mine have been.
    Here's the wiring diagram from the wiring harness Crutchfield supplied for my 2004...
  5. Nov 27, 2011 at 7:44 PM
    2000GTacoma
    Snow Hill NC
    according to that diagram its the orange white wire as well. i will check this out tomorrow and confirm if it works or not thanks for the help though
  6. Nov 28, 2011 at 1:58 PM
    2000GTacoma
    Snow Hill NC
    You are correct my stereo would not respond to the dimmer wire. Thanks for the help though
  7. Nov 28, 2011 at 6:28 PM
    Norton
    I'm sorry to hear that. Not sure why, with all the extra functionality built into aftermarket stereos, that they couldn't build-in a simple dimmer... :confused:
    You're very welcome, BTW.
  8. Nov 28, 2011 at 7:25 PM
    2000GTacoma
    Snow Hill NC
    you would think
  9. Dec 3, 2011 at 6:17 AM
    saitcho
    saitcho Well-Known Member
    New Orleans
    '11 DC 4x4 trd off road
    So they basically told you the dimmer function of your pioneer radio would never work? All you should need to get it to work is a wire with 12v on with lights on and 12v off with lights off. There is no wire behind our radio that will do that??? The "orange/white" wire isnt the right wire?
  10. Dec 3, 2011 at 8:30 AM
    WestEnd
    WestEnd Member
    Nebraska
    1998 SR5
    Maybe I missed it in your post, but which model radio do you have?
    On some cars the dimmer may be solid orange, orange/black or more commonly orange white.
    However, many radios are buing built without a dimmer circuit at all.
    If your radio does have one, connect it to the green wire on your Tacoma's radio harness. It is the factory illumination circuit.
  11. Dec 3, 2011 at 10:04 AM
    Norton
    No. As I said previously, many aftermarket stereos don't respond to the vehicle's (variable) dimmer switch. Instead, they have TWO brightness settings. The first (brighter) one is when the stereo is on, but your lights are not. The second (slightly dimmer) one is when the stereo AND your light are on. This capability is controlled through the Orange/White wire to which you refer.
    True.
    In my experience, false. My illumination wire is Orange/White, just like the aftermarket harness for which I posted the wiring diagram above. Green wires are for the left rear speaker.
  12. Dec 3, 2011 at 5:15 PM
    2000GTacoma
    Snow Hill NC
    Norton is correct I tried the wire that was labled dimmer from the factory harness that was 12v on with lights on and it would not work so i didnt bother with it however i did integrate usb ports into my truck today. 2 for data with the radio and 2 for charging usb acc.
  13. Dec 3, 2011 at 5:42 PM
    WestEnd
    WestEnd Member
    Nebraska
    1998 SR5
    I wasn't very clear. The green (illumination) wire I'm referring to is from the factory radio harness... not the aftermarket harness. You would connect the orange/white wire from the aftermarket harness to this green wire.
    The green wire I think you're talking about is the Left Rear (+) speaker feed from the aftermarket harness??
  14. Dec 3, 2011 at 5:45 PM
    2000GTacoma
    Snow Hill NC
    i have an adapter which adapts the factory over to my radio. The dimmer circuit from the factory does not do anything to my radio. I guess it does not respond to it.
