Radio with cassette tape player
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ladytalker, Sep 29, 2021.
  1. Sep 29, 2021 at 11:55 AM
    Ladytalker
    Ladytalker [OP] New Member
    1997 Toyota Tacoma
    Hi all, I have a 1997 which I recently purchased. Came with the original radio with cassette player but it’s completely dead. Checked the fuses both inside and under the hood. All is well there. What are my next steps? I have absolutely no electronics experience but I’m determined to give this a shot.
  2. Sep 29, 2021 at 11:57 AM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    Check the wiring to the radio. Maybe it's not hooked up. Otherwise, it may be time for a new unit. I recommend Crutchfield.
    0xDEADBEEF likes this.
  3. Sep 29, 2021 at 11:59 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Just replace the unit with a modern one that has Bluetooth and USB, etc; You can get a decent one for $100! If you wants CD player, that can still be had for less than $140...
  4. Sep 29, 2021 at 12:03 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You bought it with a dead radio? I'm willing to bet that the previous owner had an aftermarket installed, then swapped the original back without properly wiring it before selling.
    Might have to pull the radio. And if you are doing that, might as well replace it while its pulled.
    PennSilverTaco likes this.
  5. Sep 29, 2021 at 12:07 PM
    PennSilverTaco
    Charlie
    I actually saw this with a 2008ish Ford F-150 that was traded in at the dealership where I used to work detailing cars...
    The truck was 10 years old at the time, but mint and with relatively low miles for its age; The previous owner did hook the factory radio up correctly, but the truck had an aftermarket backup camera and I initially could not figure out why the truck had backup camera that literally went nowhere. We assumed that the owner took their expensive head unit with them when they traded the truck...
    Rock Lobster[QUOTED] likes this.
  6. Sep 29, 2021 at 12:11 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Fairly common actually. Especially the installs where they cut the original harness. They remember to keep the radio, but forget to keep the harness connector.
  7. Sep 30, 2021 at 8:48 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Sadly the next step is to pull the radio check for voltage at the truck side plug .
    Any one close to you that can help .
    For what it is worth I removed the aftermarket radio that worked and went back to the Toyota radio I don`t need all that fancy stuff I will never use.
