Radio works but NO sound
Discussion in 'Audio & Video' started by tcma07, Feb 25, 2013.
  1. Feb 25, 2013 at 11:56 PM
    tcma07
    tcma07 [OP] Chris
    C.C. Texas
    2007 Sport 4x4 v6 A/C Blk
    4" lift, Satoshi, BHLM...
    A couple days ago my radio just cut out the sound that is the unit is still on and acts like its working but is not producing any sound. Checked both radio fuses under hood and checked all wires to the speakers all is good. Does anybody know whats going on? Its a 2007 access cab with a Valor double din.
    Thanks!
  2. Feb 26, 2013 at 12:55 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Is this a JBL system that's still in use other than the new head unit? If so, maybe the JBL amp went out.
    Are there any amp in the truck for the speakers? If so, check the power at the amp.
    If neither of the above, its only 1 of 2 things... either one of your speakers has a terminal touching ground and putting the radio into a protect mode, or your radio just died on you.
  3. Feb 26, 2013 at 12:59 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    this. is it just the radio or cd’s as well? if it’s just the radio and cd and work, than it maybe the antenna plug. but most likely what proforce said.
  4. Feb 26, 2013 at 3:58 AM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    I am interested to see how this turns out. Please let us know if you find a fix OP. I have had this issue itermitantly with my pioneer head unit but a simple reset of the head unit usually fixed it. I am assuming because it resent the power on signal to the JBL amp. But I was informed that after the battery in my truck died, that this fix no longer works. I have not, and will not for a few months, have an opportunity to look into it so I am afraid I cant be much help, but I am curious about what it could be. So far it looks like maybe the JBL amp.
  5. Feb 26, 2013 at 6:56 AM
    tcma07
    tcma07 [OP] Chris
    C.C. Texas
    It's a non JBL so it's not an amp issue and I don't have an aftermarket amp either. I'm hoping its the speaker wires because I took the door panels off a couple days before this all happened and it's not the radio because I tried two others both with no luck.
  6. Feb 26, 2013 at 7:01 AM
    tcma07
    tcma07 [OP] Chris
    C.C. Texas
    It's radio, CDs and AUX. I checked the antenna wire it was still all the way in.
    Yeah it worked for about a couple mins this morning but went out as I was driving so I'm assuming its a wire grounding out somewhere.
  7. Feb 26, 2013 at 11:31 AM
    ProForce
    Anthony
    Alaska
    If that's the case, then its either a grounded speaker wire which is nothing to worry about, it won't hurt your radio or speakers in any way, but it won't work again until its found.
    The only other possibility is the actual radio ground itself. Most radios will work without a ground connected. How, I have no idea, BUT, I have seen radios do some really really really weird and unexplainable things when they have a bad or no ground. This could easily explain it.
    I'd start by checking radio ground, 12v, and acc. If all three are perfect, check the wiring in the doors you removed. Look for pinched or frayed wires, and also look at the back of the speakers (hard to do without taking them out) and see if one of the voice coils is touching the edge of the metal door.
    Keep us posted.
  8. Feb 26, 2013 at 7:33 PM
    tcma07
    tcma07 [OP] Chris
    C.C. Texas
    Ok guys i fixed it earlier today my drivers side tweeter went out unplugged it and now everything works fine now i guess ill get two new tweeters this weekend thanks for all of your input i was about to take the dash apart :D
  9. Apr 10, 2020 at 8:21 PM
    eltomasin
    eltomasin Member
    2015 tacomas
    so the tweeters cause the system not to produce sound???
  10. Apr 11, 2020 at 5:46 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Sometimes when speakers blow or go out, it creates a short in the wiring. The radio see’s this short and knows it’s bad, so it turns the internal amp off to prevent it from damaging itself.
  11. Apr 11, 2020 at 8:11 AM
    eltomasin
    eltomasin Member
    2015 tacomas
    Destin_Meeks thanks for the info i ordered new tweeters ..once installed ill give an update see if that fixes issue .
  12. Apr 20, 2020 at 12:37 PM
    eltomasin
    eltomasin Member
    2015 tacomas
    update i got a new head unit and now everything works like it should..
