Radio works only when it's cold outside
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoDE12, Feb 6, 2022.
  1. Feb 6, 2022 at 1:44 PM
    TacoDE12
    TacoDE12 [OP] New Member
    2012 Tacoma
    I have a 2012 Tacoma. The radio only works when it's pretty cold outside. When it is cold outside and the radio works, once I drive the truck for awhile and turn it off, when restarting the radio will not turn on. I have replaced the fuses under the steering wheel and under the hood associated with the radio. It has to be something effected by heat, but I can't figure it out. The cigarette lighter outlets were also not working but I switched the fuse and they work now. I've seen other threads on this but I still have not found answer that works.
    BudFriendguy likes this.
  2. Feb 6, 2022 at 1:46 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
  3. Feb 6, 2022 at 2:08 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Your factory radio is 10 years old. They are known for failure at one of the control chips/heat sinks after a few years. Sometimes they power up but no sound - amp chip/heat sink separation failure. No power - main IC power circuit failure. That ones usually a broken solder joint. Sounds like that’s what you have. Cold, everything’s tight. As it heats up, it separates, causing an issue like yours.
    Only fix is to replace. Dealers are crazy expensive. You might find one in the BST section here. Other option is to buy an aftermarket stereo with the features you want.
    wi_taco and Key-Rei like this.
  4. Feb 6, 2022 at 2:52 PM
    TacoDE12
    2012 Tacoma
    Thanks. That's what I figured was my course of action, based on other threads I have read. But I just want to make sure I do my research before dropping $$$ on a new radio if it's just a quick fix that I am not aware of.
    ZMan2k2 likes this.
  5. Feb 6, 2022 at 3:51 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Quick fix would be hitting the bone yard get one for 125.00 or so, and take the hour to throw it in
  6. Feb 6, 2022 at 4:01 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Darn I just saw you have a 2012. Ive got a 2010 HU that Ive been looking to sell...
