RADO Designs Bed Basket
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco-rado, Apr 4, 2025.
  1. Apr 4, 2025 at 6:52 PM
    Taco-rado
    Taco-rado [OP] Well-Known Member
    Michigan
    2023 TRD SPORT DCSB
    This is just the prototype and we will be looking at adding a couple of features that can be added on. A cover is a possibility. The basket does have several mounting points where you are able to use straps to help hold items in place.
  2. Apr 4, 2025 at 6:54 PM
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    It is not available yet. We did add it to the website to help show a few more pictures.
    We will run a pre order for them at a discounted price once we determine a final price and launch date. Which will be some time this month.
  3. Apr 4, 2025 at 6:56 PM
    jzone71
    jzone71 Well-Known Member
    Jeff
    I'll be on the look-out for sure and can u line x it or just powdercoat
  4. Apr 4, 2025 at 7:00 PM
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    We will most likely be coating these in a powder coat that is designed for exterior applications. We use it on all our bed racks and roof racks. Holds up better then standard PC and is also UV resistant, so it won’t fade.
  5. Apr 4, 2025 at 7:03 PM
    jzone71
    Jeff
    GREAT I'M READY TO ORDER ONE
  6. Apr 4, 2025 at 7:33 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Just in case it’s not clear… @jzone71 really really really wants one of these. Don’t mind me jzone, I’m halfway through a really good margarita.
  7. Apr 4, 2025 at 7:36 PM
    jzone71
    Jeff
    No problem,i've got a good sense of humor. :cheers:
  8. Apr 4, 2025 at 7:44 PM
    RushT
    North Texas
    There sure aren’t enough of those to go around these days! Happy Friday to ya.
  9. Apr 4, 2025 at 7:45 PM
    jzone71
    Jeff
    You as well
    MARSHBUSTER likes this.
  10. Apr 4, 2025 at 11:38 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    This is awesome! Looks like it mounts up with 6 bolts? Some kind of quick release or fasteners you could loosen by hand to remove for full access to the bed would be incredible
    TartanEagle and Taco-rado[OP] like this.
  11. Apr 5, 2025 at 3:41 AM
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    Thanks! Yes, once it’s all put together. 6 bolts is all it takes to remove and reinstall the basket.
    Quick release mounts would be a nice addition. It is something we will look into.
    With it being hard mounted in the current configuration, it gives it the most strength. It’s been tested with a static load of 350lbs and held up great.
    musicisevil[QUOTED] likes this.
  12. Apr 5, 2025 at 5:37 AM
    RushT
    North Texas
    One recommendation because it doesn’t look like it’s currently configured to do this. Make multiple side mounting points so you could mount it a little higher if necessary. I could see someone grumbling because if they had an extra inch or two of underspace, they could slight their whatever thing is too big, under there.
    <edit>. I checked the photos again… it looks like you might be able to use some of the molle cutouts to do this?
  13. Apr 5, 2025 at 5:55 AM
    Carpejohn
    Carpejohn Member
    2022 Tacoma sr5 access cab
    This looks pretty neat. How much does it weigh?
  14. Apr 5, 2025 at 6:11 AM
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    Appreciate the feedback. A couple more mounting points are going to be added in the final version. The main goal was to keep the basket below the top of the bed rail.
    This basket is roughly 7” tall.
    If there’s interest in these, we are also working on a basket that’s around 4” tall to have options.
    There are mounting points on the sides to be able to mount to our bed side Molle panels. Working on getting pictures of it mounted to those as well.
    not a charger and musicisevil like this.
  15. Apr 5, 2025 at 6:12 AM
    #35
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    Will get you a weight here later today. Thanks for asking.
    Jsevert2023 and musicisevil like this.
  16. Apr 5, 2025 at 4:56 PM
    #36
    Jsevert2023
    Jsevert2023 Toyota service writer
    Jonathan
    Eastern Pennsylvania
    Gen 3 SR 4x4 4cyl AC, 2018 rav4
    I like to sleep in my truck.
    Super stoked about the feedback! I love this from a company.
  17. Apr 5, 2025 at 5:09 PM
    #37
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Mods = N+1
    This looks awesome, great work!
    Guessing you have good reasoning for making out of steel. So asking for my own education. Any thoughts of making it from aluminum?
    again, well done. Looks amazing!
  18. Apr 5, 2025 at 5:10 PM
    #38
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    Current weight as it sits is roughly 60lbs.
    There will be more material taken off which will help cut down a few more pounds.
    Jsevert2023[QUOTED] likes this.
  19. Apr 5, 2025 at 5:19 PM
    #39
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    Main reason for the steel is price and strength.
    With the current design we’ve tested it with 350lbs of static weight, with zero deformation.
    Aluminum would be great and a potential. It would raise the price and cut down on the strength a bit. Lowering the load capacity rating.
    Making sure there’s enough interest before we get ahead of ourselves.
  20. Apr 5, 2025 at 6:14 PM
    #40
    Dtax
    Massachusetts
    Mods = N+1
    makes sense and really appreciate the thought you put into it. Best of luck with this and I am following closely. Looks awesome!
    thanks for the quick reply.
    Again best of luck!
