RADO Designs Bed Basket
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco-rado, Apr 4, 2025.
  1. Apr 5, 2025 at 6:24 PM
    #41
    Taco-rado
    Taco-rado [OP] Well-Known Member
    Michigan
    2023 TRD SPORT DCSB
    Appreciate the feedback and support!
    We’re a small family owned business and do our best to design and offer quality products for our off-road and overland community.
    Getting feedback from the community goes a long way and helps show us what you (the customer) like, and don’t like. We truly appreciate the responses as it helps us make better products for you!
    not a charger and Dtax[QUOTED] like this.
  2. Apr 5, 2025 at 6:36 PM
    #42
    Slappy Jones
    Slappy Jones Active Member
    Bay Area
    2018 Inferno Tacoma TRD Sport DCLB
    pro grill working on the rest.
    That's brilliant design, I can you selling more then a few of those.
  3. Apr 5, 2025 at 7:09 PM
    #43
    rtadams89
    rtadams89 Well-Known Member
    Phoenix, AZ
    2017 Tacoma Limited
    I'm not sure I see why this is "Width-adjustable to fit a variety of setups"? Wouldn't the factory rails this bolts to be the same width in all setups?
    Any reason the "Molle-style mounting panels all around" aren't actual MOLLE? Are these at least some even multiple of MOLLE so that existing MOLLE pouches will fit correctly?
    If you have the factory tonneau cover, is there a way to get items into/out of this without fully removing the tonneau cover (including removing the bolt that holds it on)?
    MagicToolbox likes this.
  4. Apr 5, 2025 at 7:24 PM
    #44
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    The product is designed and based on the Tacoma and Tundra beds. With that it will also fit Gladiators, and Frontiers with the accessory/trail rail systems. All of the truck beds are varying widths from 56” - 63”.
    The Molle design is the same one we run on all our Molle panels which allow for pouches and Molle/PALS bags to strap and mount to them.
    As of right now it is a bolt on product. We are looking into and will be working on an “add on” style slide system. Which will help allow access on a factory cover, when the basket is mounted against the bulkhead like pictured in our original post.
    Picture of our 4Runner Complete Molle Setup which runs the same design as the basket.
    BlackTyRD and Dtax like this.
  5. Apr 5, 2025 at 7:27 PM
    #45
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    Appreciate it! That’s definitely the hope. Wanting to offer a product that is actually beneficial and can truly help in a real world application.
    Dtax likes this.
  6. Apr 5, 2025 at 7:27 PM
    #46
    rtadams89
    Phoenix, AZ
    2017 Tacoma Limited
    Ahh very cool! Thanks for the reply
    Dtax and Taco-rado[OP] like this.
  7. Apr 6, 2025 at 6:18 AM
    #47
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    Any chance you’ve checked for clearance on mounting with a camper shell? Only asking because AllPro makes a similar setup(https://www.polyperformance.com/all-pro-tacoma-internal-bed-rack-kits) and the basket will not mount to the rails with a camper shell installed(SnugTop Rebel). The camper shell mounts to the side bed rails(sits low) and blocks the mounting plates for the AllPro setup, hoping you’ve addressed this issue so those of us with camper shells can utilize the product too.
    Taco-rado[OP] likes this.
  8. Apr 6, 2025 at 7:05 AM
    #48
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    Most toppers do not block access or require relocation of the factory accessory rail. When the rail stays in place this basket will still allow you to be able to mount it. As it does not sit any higher than the top of the accessory rail.
  9. Apr 6, 2025 at 7:12 AM
    #49
    Dorf510
    Tyler
    Vista, CA
    18 TRD 4x4
    The shell mounts to the same rail as the basket, the interference will not allow the basket to mount flush unless it is able to clear the camper shell mounts(attached photo to show the mounts on Leer/Snugtop). Id assume the mounts will not clear the basket lip, but was hoping someone makes a “drop bracket” to mount below those pesky shell mounts.
  10. Apr 6, 2025 at 7:29 AM
    #50
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    Our basket would mount up just fine to that setup you shared, seeing as the factory accessory rail is still accessible. And your still using the factory mounting cleats in that picture.
    The only issue I see is the raised deck in your bed. Assuming a drawer system of some kind. That’s the only part that would cause an issue with fitment from my perspective.
  11. Apr 6, 2025 at 8:57 AM
    #51
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    If I’m seeing your pics correctly I could actually mounts this at the end of the bed (tail gate end)as long as I have access to the factory bed rail to attach all 6 bolts? I ask because my spare tire is in the bed at the front and I’m not sure if this would fit above the tire. I also have much more room at the tail end of the bed with how my Lomax cover fits.
  12. Apr 6, 2025 at 9:35 AM
    #52
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    Yes that’s correct. As long as you have access to the factory accessory rail, this will bolt right up. It can mount any where along the rail where you have room.
    MadKatt[QUOTED] likes this.
  13. Apr 6, 2025 at 10:12 AM
    #53
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    WOW - this is bad-azz .... wish I was still living in the area I'd be knocking at the door to work there.
  14. Apr 6, 2025 at 1:57 PM
    #54
    memtaco
    memtaco Well-Known Member
    Stephen
    2023 TRD OR in Lunar Rock
    I dig it.
  15. Apr 11, 2025 at 6:48 PM
    #55
    Taco-rado
    Michigan
    2023 TRD SPORT DCSB
    For those who asked for a more “enclosed” version. I have a new lid I’m making. This was a quick version to test fit an idea. I will have a locking, hinged lid finished up next week.
    Let me know your thoughts. As well as which style you prefer. Molle cutouts or the more “enclosed style”.
    Enclosed style
    Molle Style
    Happy Friday everyone!
    Ejctt and musicisevil like this.
  16. Apr 12, 2025 at 7:08 AM
    #56
    PluckyPurcell
    PluckyPurcell Well-Known Member
    North Carolina
    2022 Tacoma Dbl Off Road
    Looks great. I had almost jumped on the other one linked above, but I like the depth of this one much better so glad I didn't. Do you know what the final dimensions will be yet? Wondering if some containers I use will fit.
  17. Apr 12, 2025 at 10:46 AM
    #57
    MtMedic
    MtMedic Member
    2020 Tacoma Sport
    Liking this and I want one. I like the molle cutout design, Less weight. I live in Alaska and I know shipping is a bitch, but I still want one, somehow.
    Taco-rado[OP] and musicisevil like this.
  18. Apr 12, 2025 at 11:59 AM
    #58
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Second what mtmedic said. I like the molle cut basket as well. Anything I would put in there would be too big to fall out of the holes. Really like the design and idea, but shipping up here would be a bear lol
  19. Apr 12, 2025 at 12:17 PM
    #59
    MtMedic
    MtMedic Member
    2020 Tacoma Sport
    Maybe a group buy? Barge it up?
  20. Apr 12, 2025 at 12:58 PM
    #60
    musicisevil
    Alaska
    2019 TRD Sport
    I’ve had good luck with Carlile freight forwarding. I keep forgetting that is what I used to get my rear bumper shipped up. You have the product shipped to their office on the port in Seattle and then pick it up at the port in ANC. It was like 50-70 bucks for the bumper I think. Should be less for these baskets since they are smaller and lighter. Thanks for the suggestion/reminder! We should look into this once the product is released
