Radon Mitigation?
Discussion in 'Garage / Workshop' started by MattN03, Sep 21, 2009.
  1. Sep 21, 2009 at 9:49 AM
    MattN03
    MattN03 [OP] Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Has anyone ever had radon mitigation performed on their home? We bought a 30 year old house with a basement a couple years ago and I thought it might be a good idea to check it for radon. After a year long test, I got the results back last week. Our level was 7.2 pCi/L with EPA recommended action recommended at anything over 4.0 pCi/L. What is involved in lowering radon levels and what kind of costs I'm I looking at?
  2. Sep 21, 2009 at 10:24 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    What type of foundation do you have. Basement? Poured concrete? Sq. ft? Do you have a sump hole? Is the basement finished?
    Sealing openings in the foundation would normally be done with a basement, with the installing of a PVC pipe into the slab and venting the pipe inconspiculously out through the side of rear of teh home or through the attic if feasible.
    A bulb in that PVC vent typically would have a fan to draw the Radon gas out of the slab before it enters the living space and harlessly out of the hoem through the PVC pipe.
    A mitigator would be required to get the reading below 2 pCi/L, i believe.
  3. Sep 21, 2009 at 10:40 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    We had ours done recently. There is a lot of shale in our area so radon is all over the place in high numbers.
    I think our entire kit was close to a grand. He installed it in about 2 hours. We got one because the kids are always in the basement. Might as well yield on the safe side.
    No "safe" levels have been established though. Realtors say 4 pCi/L. And who knows nuclear physics and its affect on human physiology better than a dude selling houses. My good friend just got his done too. He is 10 miles north of me and his reading was 15 pCi/L.
    Its basically a small hole in your basement floor with a fan outside. The fan takes the gas up a pipe just as high as your roof. Very unintrusive.
    This isn't my house but it looks like it.
    Basement floor
    Oustide
  4. Sep 21, 2009 at 10:44 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    In our area of Kansas CIty, every home is inspected for radar during the buying inspection. It is a very commen problem with houses that have basements. I think for less than a grand you can get it done.
  5. Sep 21, 2009 at 11:01 AM
    wolf13
    wolf13 Well-Known Member
    IL
    2010 V6 4X4 Access cab TRD OR
    TRD Offroad w/Tow package. LEER 100XQ topper, painted grill surround, 08 cup holders, scangauge II
    I had it done on the house I bought this year, think it was 1200. they sealed around the sump (poorly), installed the vent pipe (mine blends in much better) and t'd it in to draw from two places and sealed up a dirt floor room (building is a 100 yr old former bank). they did NOT seal an open hole in the basement wall or any cracks. Was overall not too happy with it and ended up feeling like it was a waste of money, but I also knew I wouldn't be living here forever so decided to get it done with someone elses money rather then the next buyers making me do it with my money ;)
  6. Sep 21, 2009 at 11:16 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    All i can offer is my nuclear engineering knowledge. 7.5 pCI/L is not a large amount of radiation. The maximum non occupational exposure to people near nuclear plants is 4pCi/L which is nothing compared to what we get everyday from concrete, granite, cosmic sources, etc
  7. Sep 21, 2009 at 11:42 AM
    MattN03
    Bluegrass State
    We have a basement with a poured concrete slab. It's approx 1000 SQ FT. We do have a sump pump hole-but it's on the exterior wall that is buried-the opposite side is the walk out side of the basement. The basement is finished :(
  8. Sep 21, 2009 at 11:46 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    IMHO, it's all quackery. You get more radiation from outer space...how ya gonna mitigate that?
  9. Sep 21, 2009 at 12:19 PM
    WNYTACOMA
    Clarence, New York
    They would probably seal the sump and install the PVC pipe and fan and re-test to see what effect it had on the level. My guess is you would fall in the $1000-$1200 range, though i suspect prices will vary by region. A less involved mitigation, regardless.
    I don't do the mitigation, but i do the testing as part of my Home Inspection service when requested.
    Radon gas is alleged to be the 2nd leading cause of cancer behind the obvious, (butts) so i can see the concern by some. The EPA site gives you probablilities with certain measurement ranges in the event anyone is interested. They liken probabilities to things such as getting in a car accident or struck by a bolt of lightening. It is called the 'Citizens Guide to Radon'.
