Rail Nut inserts?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WaynesWorld69, Jan 27, 2018.
  1. Jan 28, 2018 at 1:03 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
  2. Jan 28, 2018 at 1:06 PM
    sea_ledford
    sea_ledford Active Member
    2018 DCLB OR Cement
    peeled off the dealer sticker
    Because I'd rather shop local than buy on-line I looked at Lowes, Home depot, and 2 local hardware stores... none of them had anything like a t slot nut. Looking on-line at those stores for strut threaded inserts didn't produce anything either.
    A quick google search for "strut threaded inserts" came up with this for @Admiral_Akbar though:
    https://www.garvinindustries.com/ha...MI7rWS4cb72AIVVrXACh0x7gpEEAQYBCABEgKC9vD_BwE
    Not sure if it is the correct dimensions, but looks like it would be close.
  3. Jan 28, 2018 at 1:14 PM
    Spackler
    Spackler Well-Known Member
  4. Jan 28, 2018 at 1:36 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    It's not powder coated unitstrut. And spring nuts don't work correctly on the rolled lip of the bed rail. You can get em to bite, but it's mostly corner to opposite corner. So it's only bearing on two points.
  5. Jan 28, 2018 at 2:19 PM
    mast75
    mast75 Well-Known Member
    Wilkes Barre,Pa
    2018 WHITE TRD OR DC SB AT
    TRD oil cap,Tacoma bed mat,vent visors,Undercover Tonneau cover,tinted windows,remote start,auto armor,SS toyo exhaust tip,OEM Tacoma tailgate Letters
    It’s cheaIf you do not want to pay ~$200+ for the OEM bed rail system then a cheaper alternative is to use electrical Unistrut. It is virtually the same as the OEM bed rails except it is a little wider and i believe stronger.
    Rails-Unistrut
    3 sticks of 10' long Unistrut from a local hardware store: Link to website
    3@$16.34 = $49.02
    Installation Hardware
    (12) M6 x 1
    (12) 1/4" fender washers
    Mounting Hardware
    3/8” Unistrut channel nuts: Link to website
    3/8” Hex Head Bolts (length depends on what your attaching)
    3/8” Lock Washers
    3/8” Fender Washers
    [​IMG]p version of unistrut minus the spring on the spring nut same principle.
  6. Jan 28, 2018 at 4:17 PM
    WaynesWorld69
    WaynesWorld69 [OP] Member
    Wayne
    2017 Tacoma TRD Offroad
    Inconel because I'm going to TIG weld some ENiCrFe-7 eye slip hooks onto an Inconel bracket I fabbed in the shop. I don't want any cross contamination with any Carbon or Low carbon alloys parts. I have access to inconel blocks at BWXT where I work that i can machine into the inserts but was wondering if they're available for sale first before I waste time machining.
  7. Jan 28, 2018 at 4:19 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    That's not what op was asking for. He has the bed rail already.
    Gunshot-6A likes this.
  8. Mar 8, 2018 at 4:00 PM
    tatacoma
    tatacoma Member
    Tom
    North Carolina
    2011 Grey Tacoma Prerunner Access Cab AT 2.7 motor
    Kenwood Sound System, Local bird poop
    Will these fit the 2nd Gen Taco rails?
  9. Mar 8, 2018 at 4:21 PM
    sandyTrd87
    sandyTrd87 Well-Known Member
    Socal
    Bilstien 5100's x4 Dobinson 448 springs, rear 2inch AAL
