Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Aug 1, 2016 at 5:20 AM
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    That sounds about right, without looking at it. Don't crimp wires together doesn't get a good connection. If you can soder them
  2. Aug 1, 2016 at 5:27 AM
    CO_0321er
    CO_0321er Well-Known Member
    Okay. So ideally i should take both light wires, soder them together, then connect them to the wire running to the relay.
    Don't have access to a soder, I know they are cheap but I might try just twisting and plugging into relay wire.
  3. Aug 1, 2016 at 5:30 AM
    mrbedgood
    North Carolina
    Do you have a relay involved somewhere in there?
  4. Aug 1, 2016 at 5:38 AM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    Been MIA for a bit...catching up on stuff.
    Sandman614[OP] likes this.
  5. Aug 1, 2016 at 5:40 AM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    You can solder them over here tuesday. Im not really good at wiring it self, but making it clean im decent at
  6. Aug 1, 2016 at 5:44 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    This isn't entirely accurate.
    A crimp or "compression" connection is better in a high vibration environment, solder will make connection too rigid and can break easier. Nothing is 100%
    Every connection in your truck is crimped and will last for years (on average)
    How well you make the crimp is the real point. Too loose, you have a poor connection, too tight and you'll crush the wire and it will break at the crimp.
    The tool used is also key in making good crimp connections.
    Save soldering for electronics
    Shockwave likes this.
  7. Aug 1, 2016 at 5:54 AM
    mrbedgood
    North Carolina
    I've never had an issue with soldering wires together and using soldering wire. Then heat shirking it all. I've done that with all my light and retro fit lights wiring.
  8. Aug 1, 2016 at 5:55 AM
    mrbedgood
    North Carolina
    Where have you been?
  9. Aug 1, 2016 at 5:56 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Yea there deff two schools of thought there. I've heard every argument with people coming in my work, video, you tube, directions on stuff i get in PC/auto. Just do what you feel comfortable with. Me i will always solder two wires together befor using a butt conector. If is a connection that needs unplugged Ill use a good waterproof one that has wires to solder too. eyelets i cut the plastic off, crimp it then solder it. Use heat shrink. there probally over 300' heat shrink on the Seagull, i was buying it 100' rolls
  10. Aug 1, 2016 at 5:57 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Everyone should voice there opinion on this subject!! Interesting what others do
    mrbedgood likes this.
  11. Aug 1, 2016 at 5:59 AM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Just been doing other stuff. Trying not to spend all my monies on my truck ;) Spending time with my daughter while she's been home over the Summer.
  12. Aug 1, 2016 at 6:04 AM
    mrbedgood
    North Carolina
    That's totally understandable dude. Time with family is the best and always needed
  13. Aug 1, 2016 at 6:13 AM
    CO_0321er
    Yes the wiring switch has a relay. That's what my question was, connecting the two lights to the wire that runs to the relay, so both are controlled with one switch. I may just try twisting them together and crimping. If that doesn't work well then I'll try soder.
  14. Aug 1, 2016 at 6:18 AM
    mrbedgood
    North Carolina
    Yea wire the wires together on to one plug on the relay. A wire from the relay to the fuse then to the battery. A wire for the ground from the relay as well. Then the last wire will go to the switch
    CO_0321er[QUOTED] likes this.
  15. Aug 1, 2016 at 7:22 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I prefer crimp butt connectors that have the glue heat shrink on them. It helps to hold the insulation together and keep water out. Best connection in my opinion.
    Also waterproof connectors like weatherpack are the best! Crimp them (like they're supposed to be, with the correct tool) so you don't melt the seals trying to solder.
    Blkvoodoo[QUOTED] likes this.
  16. Aug 1, 2016 at 7:24 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Daughters been home and you don't want to hang out with creepers lol. *sorry trying to make a joke*
    I still got your ratchet and fan.
  17. Aug 1, 2016 at 7:33 AM
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    I've been talking mad shit about you.
    Glad ya back, kinda miss ya little poultry self...
  18. Aug 1, 2016 at 7:46 AM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    so much love in this place :p
    voz likes this.
  19. Aug 1, 2016 at 8:01 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Just put in the "final" order to replace my battery cables and terminals. I'll be installing my new battery and wanted the wiring to be upgraded. 2ga battery to starter, 4ga alternator to fuse block and fuse block to battery.
    voz likes this.
  20. Aug 1, 2016 at 8:09 AM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    dual battery? Or big 3 upgrade?
