Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Aug 6, 2016 at 12:17 PM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    This junk is dang good
  2. Aug 6, 2016 at 12:20 PM
    ThunderCookies
    ThunderCookies This is the Wait
    Jon
    North Carolina
    06 Wolfpack Edition
    5100s at 2.5 setting up front 5100s with 2" AAL around back TC Uniball UCAs 285/70/17 Fierce Attitude M/T SCS Ray 10s 17” 14" Magnaflow w/3.5" Stainless Tip SOS aluminum armor front bumper SOS high clearance rear bumper Stealth grill light bar and pods 4" Westin Nerf Bars Weathertech in-channel visors Window tint Bed Mat Proven Ground Locking Roll-Up Tonneau Cover All-weather rubber floor mats Custom Wolfpack TRD Decal TOYOTA Vintage Tailgate Decal 4 Wheel Drive vintage decal Tailgate Anti-Theft Mod Bed Mat Anti-Theft Mod Sliding back glass Anti-Theft Mod Future Mods: Bedside bottle opener Bedside storage lock/key mod Bed pod lights
    Dang what a bunch of BS. I paid $60 and he did not exactly what I asked...
  3. Aug 6, 2016 at 12:26 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Glock
    Carrionman likes this.
  4. Aug 6, 2016 at 1:11 PM
    Carrionman
    Carrionman Well-Known Member
    James
    Eastern NC
    2013 4x4 v6
    Trying to avoid that if I can but I may have no choice
  5. Aug 6, 2016 at 1:21 PM
    CO_0321er
    CO_0321er Well-Known Member
    Lol I mean I'm trying to get rid of a Trijicon RMR
    nastyneight[QUOTED] likes this.
  6. Aug 6, 2016 at 1:27 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Bunch fucking bastards.. Time to go to Charleston and see @ahspurlock. Come with me and @RaleighTaco tomorrow.
    tacopaulo[QUOTED] and ahspurlock like this.
  7. Aug 6, 2016 at 1:29 PM
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    Hell yea bring it on
  8. Aug 6, 2016 at 1:37 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    @Dragonslady y'all left a box of stuff at Nates, I got it.
    ahspurlock likes this.
  9. Aug 6, 2016 at 1:43 PM
    ahspurlock
    Adam
    I'll take it don't know what it is but I don't care lol
  10. Aug 6, 2016 at 3:29 PM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    So...Looked at a Jeep XJ today for my wife to putter around in. 200k miles. Drives nice everything works for the most part....lift gate has the normal issue with the latch. Has some rust along the bottom of all the doors and lift gate...not super bad but noticeable. Cat needs replaced and it's getting misfires on 2 and 6 as well as lean on both banks ( which is likely causing the misfires ) I offered $2000 but he's trying to get "close to $2500" which means there's some room. I don't know much about them....any thoughts?
    http://raleigh.craigslist.org/cto/5702663081.html
  11. Aug 6, 2016 at 3:52 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    It that the one sitting on Old Stage ?
    misfires in the 4.0 a lot of times is clogged injectors, which end result leans out those cylinders and ends up burning valves (this is very common) which is the cause of the actual misfire.
    Most likely the reason the cat needs replacing as well, leaned out over heated and melted cat. You won't know for sure about the miss fires without at least a compression check to determine if there is a valve issue or not.
    You've already established its running lean.
    A Cat can be had from Rockauto for $140ish
    pulling the head on that engine is pretty straight forward, basic valve job isn't terrible cost wise, parts aren't terrible cost wise. time and labor for DIY, whats it worth to you.
    its a 16yo beater with a heater ( does the AC work ? )
  12. Aug 6, 2016 at 3:57 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    If the cat is actually even bad. I see too many people jump straight to replacing cats without fixing the cause first. Things don't have an expiration date on em and go bad.
  13. Aug 6, 2016 at 4:17 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    P0420 is usually pretty on spot, the post O2 is not seeing the temp change it needs to. it is possible, and it is commonly mis-diagnosed. I would check a lot of other things before just replacing the converter.
    Converters DO fail and not show codes as well, when they clog or melt.
    I agree, i'd go for the root cause before the symptom of bad cat.
    I mentioned the cat cost as they aren't terribly expensive as most shops ( which use the same parts vendors as Rock many times ) will inflate the cost 3x-4x as folks do not generally know. ( this can be a bargaining point too when purchasing used vehicle )
    An OEM cat is gonna be expensive, they have stringent mileage and time intervals they have to meet by law, aftermarket, not so much.
    Also, many earlier vehicle emission maps have an algorithm built in that ignores post cat signal after XXXX hours of run time and allows them to pass OBD. the catalyst does wear and decline in efficiency over its lifetime. They still work, just not as efficiently as they once did. The biggest reason the EPA doesn't want your beater with a heater on the road after 20yrs, they just can't come out and directly say it (YET)
    https://www.youtube.com/watch?v=nNzMX5fhypU&feature=youtu.be
    https://www.youtube.com/watch?v=E5j6dFFLId0&feature=youtu.be
  14. Aug 6, 2016 at 5:06 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    my code reader showed 300 (multiple random misfire), 302(cyl2 misfire), and 306(cyl6 misfire) also showed 171(lean bank 1) and 174(lean bank 2) The cat rattled at idle and if you bumped it with something it rattled inside as well. It drove fine only felt a little rough idle at a stop. The AC does work and it seems like a decent project but I think I'm gonna pass and wait for another project to come along. Thanks for the input.
  15. Aug 6, 2016 at 5:07 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    and yes ...it's the one on Ten-Ten near Old Stage
  16. Aug 6, 2016 at 5:22 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I know people don't agree with me but I had a lean condition, with p0420, and after several attempts and diagnosis, the fuel pump fixed it.
  17. Aug 6, 2016 at 5:51 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    @Sandman614 will you be going to SOS while in SC next week? if so will you ask @EddyRRT if he has any of his shackles? tried calling but never got thru
  18. Aug 6, 2016 at 6:00 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea ill ask.
  19. Aug 6, 2016 at 6:02 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Soo Cafe chicken might be soo good buts Idk cuz it's taking soo long. @tacopaulo is killing me.
  20. Aug 6, 2016 at 6:05 PM
    Carrionman
    James
    Eastern NC
    2013 4x4 v6
    You calling the parts department or shipping department over there? @EddyRRT
    :bananadance::cheers:
    HrBrad8 likes this.
