Raleigh North Carolina and surrounding areas
Discussion in 'South East' started by Sandman614, Aug 22, 2013.
  1. Aug 30, 2016 at 1:14 PM
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    nice that looks real good
  2. Aug 30, 2016 at 1:54 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  3. Aug 30, 2016 at 2:04 PM
    mrbedgood
    North Carolina
    Has anyone every used or know if Alcan springs are any good?
  4. Aug 30, 2016 at 2:42 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    @T4RH33L has manual hubs so no cv axle nut, ADD trucks have the nut, Sway bar link end, 4 bolts bottom of spindle, bottom strut bolt, 3 up top, boom, out, reverse procedure for reassembly.
    If struts/springs are not assembled, have that done before hand, cost isn't that much. But you will need to buy top plates and the rubbers if you don't already have them.
    Not a tough job really, rust can aggravate the disassembly process.
    The biggest gotcha could the be rear lower shock bolts, they can break in the stud and you'll end up drilling or some other creative method of reassembly. The bolts thru the front of the spring eyes are sleeved also, so those may have to be cut out, the rear shackles move in rubber so those come apart ok. You'll end up cutting the center bolt out of the spring pack most likely if you decide on add a leaf.
    voz likes this.
  5. Aug 30, 2016 at 2:43 PM
    andrewb
    andrewb Well-Known Member
    NC
    2015 Tacoma
    JB weld + bolt?
  6. Aug 30, 2016 at 3:21 PM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    you sure it's 7/8"? usually it's 19mm
  7. Aug 30, 2016 at 3:33 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    OD is 7/8, I'll look for 19mm
  8. Aug 30, 2016 at 3:34 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    yeah...the plugs are ID
  9. Aug 30, 2016 at 3:43 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    *note: Australians call them spigots
  10. Aug 30, 2016 at 4:11 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    duly noted ;)
  11. Aug 30, 2016 at 4:44 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Do you know where to get them in the US.. Seems like no one in the US uses them..
  12. Aug 30, 2016 at 5:47 PM
    2000TRDTaco
    2000TRDTaco Well-Known Member
    Corey
    Angier, NC
    00 Prerunner
    19mm is equivalent to 3/4" more or less
  13. Aug 30, 2016 at 7:15 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Still can't find any in the US.
  14. Aug 30, 2016 at 7:30 PM
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Go ghetto, use a cork with a nail threw it
  15. Aug 30, 2016 at 7:35 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Thought about it, home Depot didn't have any of the rubber stoppers. I guess I can wait for the slow boat from England or Australia, it's not like I have the rest of the material yet.
  16. Aug 31, 2016 at 11:58 AM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Pit some POR15 down to cover some surface rust
    voz likes this.
  17. Aug 31, 2016 at 12:29 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  18. Aug 31, 2016 at 12:31 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    :woot:
    Smiley52 and nastyneight like this.
  19. Aug 31, 2016 at 2:55 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    where da eyeball vents?
  20. Aug 31, 2016 at 3:04 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Coleman has some plastic ones
    http://bit.ly/2crMPrF
